Question about Jensen JTA460 Turntable
Turntable turns too slow
All three speeds 33 / 45/ 78 music seems slow
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
Mar 24, 2014 | Technics SL-BD20D Turntable
Speed seems a little slow on 33s. How can I fix this?
If the problem is encountered on both speeds, 45 & 33, then there is a high chance that you are in need of a belt replacement.
Here is a general guide on how to replace a turntable belt.
You can also use it to check the belt status.
Jul 23, 2013 | Aiwa PX-E860 Turntable
Yorx turntable speed issue, And turntable is warped.
You may be experiencing Acoustic Feedback, although it doesn't really make any sense the way you describe it. Make sure the tonearm is balanced and the proper weight is dialed in on same. Does it make any difference if the volume or bass are turned down, which my point to the Acoustic Feedback.
Jul 04, 2012 | Audio Players & Recorders
THE SPEED SEEMS TO BE A LITTLE SLOW
On most turn tables there is a knob or a lever to adjust rotational speed. If it does not seem to have one then the motor is most likely out of sync and would need to be manually adjusted.
Mar 13, 2011 | Audio Players & Recorders
Speed seems to be slowing down every so often but then it will resume speed
Chances are you need to replace the drive belt.
These are easily available online (try Ebay or Amazon) just search by make and model number.
To access the belt you will normally need to turn the turntable upside down and unscrew the base.
Feb 17, 2011 | Kenwood Audio Players & Recorders
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Jan 08, 2010 | Sony PS-LX250H Turntable
Magnavox Console Stereo turntable does not turn at correct speed
I'm in Nashville, where can I have my 70"s Magnavox stereo console serviced to get bugs out of it as well as get new cartridges?
Nov 24, 2008 | Teac AG-V1050 Receiver
Jensen JTA460 Turntable Logo
80 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
