Question about GPX HM3817DTBLK Shelf System
Stero quit working no power - GPX HM3817DTBLK Shelf System
My jensen stero quit working
The most common cause when this has happened to me is a short in one of the speaker wires. "Quit working" means it turns on but no sound?
Jul 17, 2016 | Jensen Car Audio & Video
After i instal a dual car stero i decide to ad a
probably picked up the wrong power wire for the unit and the power is diverted to the ignition circuit.. have the installation checked by professional audio fitters.
Aug 27, 2014 | Cars & Trucks
My card reader ot working with car stero but work on pc
The problem might be with the card slot of car stereo. you may consult with stereo technician for help.
Apr 15, 2012 | Computers & Internet
Power going to stero but no power coming from stero
I don?t exactly understand your question if power is going to the stereo now I guess you need power as an out put to turn on an amp. Or what is the application you need this for.
Jan 01, 2010 | Clarion Car Audio & Video
Kenwood steroe wont turn back on after few days of working
check the fuse on the back of the radio, as well as the circuit fuse sending power to the radio
Jan 14, 2009 | Kenwood Excelon KAC-X541 88W x 4 Car...
Electrical problems with the a/c and stero control lights
Check charging system..may have a bad alternator. good
luck
Dec 19, 2008 | 2004 Infiniti G35 Sport Coupe
ELECTRICAL PROBLEM
The prob seems like you have connected the power to your stero from the wrong place. You cut into live a wire for the power, this should be connected at the ACC on your fuse panel. Also make sure you stero has a good ground! Frankster016
Oct 23, 2008 | 1989 Ford F 150
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
80 watt impedance matching volume control
check your spekaer cabling first for any loose connection. if everything as usual then something is wrong with either your speaker system or the power output stage of your amp. you may call it a "circuit breaker" but it actually overload protection of the power amp so as not to damage speakers or amplifiers. have your speakers checked for burn coils. you can also try to remove or turn off speaker switch, turn on the power, level up the volume and see it the system still stays on and does not trip (as you called circuit breaker) if the unit remains on, then it must be your speakers. though it could also be a leakage in the power transistors of your output stage, it something a technical person have to do to check anyway.
redrivera
Mar 25, 2008 | Audio Players & Recorders
GPX HM3817DTBLK Shelf System Logo
37 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
