Question about Staedtler COMPASS,HALF PIPE,BE - 9582black
How do you open staedtler 9582 compass - Staedtler COMPASS,HALF PIPE,BE - 9582black
Address of:Mr. Trevor Prestage, in Mandurah WA 6210, telephone 9582-7438
type the name in google and you get a trevor prestage site that relates to a facebook
log in there to see if he is the person
or use google white pages and put in the name and phone number to get an address
Jun 07, 2017 | Computers & Internet
WHERE IS THE REMOTE COMPASS MODULE ON A 2008 JEEP COMMANDER
wow no symptoms stated just the boring where is it...
but great question, names car and year, clearly
we've posted the full fsm online here 100s of times.
here we go again.
down load it, then type , (after opening it)
control F, the type compass.
i wonder if a compass car has compass , omg.
i have 2010 and have same book.
did you scan the PCM yet, i bet not.
and its guess what, telling why it fails right now.
see page 8M-6 in book FSM.
the dtc shows car needs degaussing,, now.... see?
and if that error happens the compass goes blank, RTM?
8m-20
calibration, RTM
replacing first is "overthetop", why go there.
first are scans then tests.
or needs just a degaussing... (a tool)
page 27
"NOTE: In addition to the Universal Transmitter
operation the Electronic Overhead Module (EOM)
is responsible for some of the compass functions.
Anytime the EOM is replaced the compass variance
value must be set, (Refer to 8 - ELECTRICAL/
OVERHEAD CONSOLE/ELECTRONIC VEHICLE
INFO CENTER - STANDARD PROCEDURE - COMPASS
VARIATION ADJUSTMENT)."
not only that the PCM can lose commmications with this OEM.
so not scanning all modern cars, is a road to doom.
why skip scanning the car first and checking fuses.?????
scan first
ask questions 2nd.
my motto.... and WIN
Dec 31, 2015 | 2008 Jeep Commander 5.7
Bellind duel fuel stainless steel cookerHow do I restore numbers that have worn away on my oven temperater guide
Staedtler fineline permanent marker.
peel off letter sheets from craft shop.
contact manufacturer ask for transfer to be posted to you
Mar 02, 2015 | Belling FSDF60DO 60cm Freestanding Dual...
How do I use a staedtler arco compass set
http://www.staedtler.us/en/products/technical-drawing-instruments/compasses/mars-comfort-551-precision-compass/
There are basically two arms to a compass. One arm usually has a point, which you can remove and reverse and or replace with different points for different paper. The other arm has a leg which can be disconnected and replaced with other legs. This arm usually holds the lead or a ruling pen. To remove the leg simply turn the thumb wheel counter clockwise ( lefty loosy, righty tighty) untl you can pulll it out. The other legs have the same fitting you slide in and then tighten the thumb wheel. You may have a very long leg you can add to make a very large circle. Hope this helps.
Nov 18, 2014 | Staedtler Arco Compass Set
Compass
I'm not 100% sure (I'm a new Nexus 7 owner), but I have see some solutions out there. The consensus seems to be that the accelerometer or the magnetometer isn't properly calibrated.
There are apps out there which claim to calibrate your device sensors, but sometimes these apps need to remain open. Compass is often recommended.
The best (and most odd) solution I've heard is to have the app open and wave the nexus 7 around in a figure 8 pattern. Apparently this does some "voodoo magic" and the device seems to calibrate itself.
Lastly, I have also read that android compasses never seem to point to true north in apps like Google Sky, but is more apparent in larger devices.
If that doesn't help I would suggest contacting Google Support to see if there is a better solution or if they can swap it out.
Phone Number: 1-855-83-NEXUS (63987)
Best of Luck!
Dec 19, 2012 | Google Nexus 7
2002 jeep Compass & fuel millage stop working sometimes
test the gauge compass +full , for open , corrosion, wires. 2) resistor open normall by 10 ohms 3) maybe can use the thermistor test for open or defective 3) test for open fuse or bad contact fuse, dirty or corrosion or loose wiring.
you can go for download the diagram to www.autoelectronico.com this web is spanish however you can translate. I strong recomend you by powerful information update+links DOWNLOad free in PDF format. try it and fix it.
God bless you
Jul 10, 2012 | Jeep Grand Cherokee Cars & Trucks
I need a new compass for tasco 322 BCW waterproof binoculars. Any ideas where I can find one?
Open the battery door, clean all inside with Alcohol & Q-tip. Check that the AG10 or 389 batteries are positive up. Now the compass dial pivots on a shaft. It seems to get caught. Take a strong magnet and rotate it above the compass lying horizontal and spin it until it spins freely. Take it away slowly. Does the compass settle down to accurate heading? If so place back in the top of the model 322BCW observing the glued in marks on the clear window area. Re-screw in, press brass button red LED should light.. If NOT recheck for corrosion. Regards, Don
Jul 03, 2012 | Tasco Optics
I have never used a dive compass before. Is there a manual as I bought it on ebay?
There is no manuals for scuba compass, I dont know what scuba school you hold your open water cert with but all scuba organisations such as PADI, SSI etc etc will cover navigation as part of there basic and advanced scuba education.
Sep 22, 2010 | Oceanic Clip Mount Maxtilt Compass -...
Compass out of whack
You need to recalibrate the compass. The procedure is in your owners manual. Here are the basic steps.
First, you will need to verify that your compass zone is set to your current geographic location. Since I do not know where you are located, I cannot tell you the code. They are listed in the manual. (For example, So Cal is zone 5.)
Second, here is the compass calibration adjustment procedure:
Perform this adjustment in an open area free from steel structures and high voltage lines. For optimum calibration, turn off all electrical accessories (heater/air conditioning, wipers, etc.) and make sure all vehicle doors are shut.
1. Start the vehicle.
2. To enter the compass calibration mode, press and hold the button for greater than eight seconds. The display will then show CAL in the display window.
3. Drive the vehicle slowly (less than 3 mph) in circles until CAL indicator turns off. As many as 5 complete circles may be required.
4. The compass is now calibrated.
Dec 19, 2008 | 2005 Ford F-150
Staedtler COMPASS,HALF PIPE,BE - 9582black Logo
65 people viewed this question
Top Staedtler Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Staedtler Office Equipment and Supply Expert? Answer questions, earn points and help others
