Question about Drills
I have a problem with my hammer drill, when connected to the power chisel and the metal part of the tool become electric conductors I realized that began to generate sparks when I was making contact with wiremesh as it was demolishing a concrete hardstand reinforced mesh, I did a test concetando a focus and one of the wires to make contact with the chisel and the equipment connected to the energy and lit the focus, as with my hammer drill?
  • 3,334 Answers
It has an internal short so i would not even plug it in until you get it fixed
Posted on Jun 13, 2017
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Posted on Mar 27, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 211 Answers
SOURCE: pbh 2200 re hammer action drill
hi
try to figure out how the switch operation mode works and put back together right.
bye savumihai71
Posted on Sep 16, 2009
harlan301
  • 205 Answers
SOURCE: New bosch psb 550 re with hammer action. Hammer
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Posted on Oct 15, 2009
How do I get a drill bit out of the shaft of my rotary hammer drill snapped in it. No bit showing.
unmount the locking rings pins or ball of the toolholder while chisel is inside its possible make the parts short time hot with a burner not to long (where safety glasses ) and leather apron in case of splinters that can come off . spray some wd 40 on the hot part before use a bench vise to set the chisel in with machine on it and the beveled edge of the benchhammer on the front of the tool holder and with a second hammer beat the other site on the benchhammer to work slowly the machine will come off from the chisel. in most cases the drill guide has been worn out from the chuck in case off a cheap rotary hammer it make no sense to do it all. because it has had it working hours on it.
Oct 19, 2015 | Rotary Drills
Can this drill be used as a hammer only for chipping?
if it is an elcheapo drill then it cannot be used for hammering only
it can only be used as a drill or a hammer drill
what you need is an expensive hammer drill ( Ramset or HILTI for masonry work that can accommodate a chisel tool and be used for chipping
however if you want to just chip there are cheap air driven chisels , that will do the job
find a good tool shop and there will be a range of tools that will do what you want
Sep 13, 2015 | Hammer Drills
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Where can I buy replacement chisels? No one to have them for my unit.
SDS Plus is a common connection end. Several companies make them. I have not heard of a carbide tipped pointed chisel. only a carbide tipped chisel blade and bushing tool. Hilti makes very good chisels that will fit the Bosch. Hilti's number is 1800-879-8000
Jul 28, 2011 | Bosch Tools Sds Plus Hammer Steel Carbide...
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
Stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
Jun 28, 2010 | Bosch 11265EVS 158 Spline Combination...
Drill/chisel drops out when useing
if it is the pull-back locking system to hold in the chisel, or drill bit, then the locking- clutch mechanism is worn and needs replaced
Jul 22, 2009 | Makita HR3000C Electric Rotary Hammer
Hammer drills and rotary hammers comparison
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Drills Logo
371 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
