Question about KitchenAid KIRD861HSS Kitchen Hood
Problem with KitchenAid KIRD861HSS Kitchen Hood
Top falls off
3 Suggested Answers
SOURCE: How can you manually open the Kitchen Aid KIRD861HSS?
By removing the decorative cover plate you somewhat expose the units inner workings. Carefully, insert a small sharp object into the unit at the point in which the micro-switch(es) are exposed. The micro-switch(es) will appear as small little plastic tabs that are poking out. While simultaneously depressing the power button, insert the sharp object into the micro-switch(es) closing the circuit. The down draft will raise enough to the point in which you can re-seat or install the filter thus making it operational.
Posted on Jan 28, 2010
grumpytoolgu
  • 69 Answers
SOURCE: KitchenAid KHTU160KSS Kitchen Hood makes noise
Remove the fan and motor assembly from the hood (the fan motor will plug into the hood housing) and using an electrical motor cleaner (such as CRC electrical motor cleaner available from your local auto parts store) wash the motor and fan as completely as possible, lubricate the end bearings (sparingly) with a very light oil such as sewing machine oil, gun oil or as a last resort 3 in 1 oil. Hope this helps.
Posted on Dec 14, 2011
Removing over the hood microwave
There is no microwave hood on a Kitchen Aid blender
Sep 06, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How do i remove the glass top to replace a burner?? it is to a kitchenaid electric range suberba, model KESC307HBS0. Thanks!!
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Range-Parts/Model-KESC307HBS0/0593/0124160/W0105111/00001?blt=06&prst=0&shdMod=KESC307HBS0 this parts breakdown gives you an idea of what pieces you need to remove to get to the burners. Start off by removed the trim pieces (careful they scratch easily). Then you should be able to raise remove the glass top - careful that you secure it somewhere that it doesn't fall over and break.
Jul 02, 2011 | KitchenAid KESC307 Electric Kitchen Range
I tried to ignite stove with electric ignite but nothing happen and I do not smell any gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 05, 2011 | KitchenAid KIRD861HSS Kitchen Hood
Hello, where can I locate the replacement filters for my Whirlpool down draft model number KIRD861HSS
There should be a 1 or 0 at the end of the model #. Either way it uses the same part #. There have 2 different filters that can be used. One is probably stainless and the other is probably plastic due to the price difference. You can get them at: http://www.searspartsdirect.com/partsdirect/index.action
Type in your model# and select model# for type of search. Depending on your model, it will be #33,33A, or 33B on the drawing.
Hope this helps you out
Happy Holidays
Mr Tin Man
Dec 29, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Retractable vent stuck
after struggling for hours to remove vent for cleaning, I just happen to pull frong panel forward, and that release the vent so that i could clean it. No big deal. Simple
May 29, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Jan 27, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
Hood does not pop up when depressing the push button
The filter elements are mostly likely not correctly in place so the latch is not tripping the micro-switch. Using a flash light this was clear by looking down into the front edge of the vent unit. I could see the element edge and the latch of the filter element. It wasn't latched tight. I used a paint scraper (two). Gently i nserted it while also using a flash light to see. I was able to lever and jiggle the filter element back into place and latch it. This activates the control. Then the unit would raise. I double checked the filter latches to be sure they were tightly closed.
Oct 31, 2007 | KitchenAid KIRD861HSS Kitchen Hood
KitchenAid KIRD861HSS Kitchen Hood Logo
102 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
