Question about Babylisspro Pro Babttw5586 Tt Tourmaline Titanium 5000 Dryer
Reset button does not work
My hair dryer stopped working and the reset button will not stick.
I have a babyliss hair dryer mod. 6619E type S54d The dryer turns on but after a few second it turns off What is the reason.
is it throwing a reset switch on its plug head? if so press the reset button on the plug head if it trips again there's an issue inside the hair dryer thats making it shut off power to it from the plug head
Apr 21, 2017 | BaByliss Dryers
Conair hair dryer 1002axa stopped working
The thermal cut-out on hair dryers is usually self-resetting, the device will restore power once the unit cools down... Most of these types of problems are due to lint clogging the air intake and causing overheating, be sure to clean the intake before attempting a repair.
May 23, 2016 | Dryers
Reset button won't work
Does the power stay on if you hold the red button in?
If the reset button does not work anymore, it's dead. Those things are not repairable, I've tried.
You don't really 'need' that thing on the end, if you live in a modern house with GFCIs in the bathroom. It's a little extra safety device, in case you have an old house without modern wiring.
You can cut the cord at that end and attach a new plug from Home Depot.
Jan 18, 2015 | Babyliss Pro Ceramix Xtreme Hair Dryer
Jilbere Porcelain Series Hair Dryer.the blower doesnt work anymore,it happens when I was drying my hair.The motor smells normal not burned and I already check buttons for reset and no luck.
On the end there shouldbe a vent which houses the fan you should be able to open this by twisting ? Chech to see if there is hair/fluff/dust blocking this if it's not able to move the motor won't have anything to keep it cooled resulting in smelling burning as the caught up hair fluff and dust burn hope this helps :-)
Jun 08, 2014 | Dryers
I plugged a hair dryer in my room then it wouldn't come on in both rooms but all the other rooms outlets work this is the second time this month this problem has occured
Please check the circuit breaker fuses. The one in your bedroom is of lower amps. If it is 5 amps replace it with 15 amps. Also check the connections of the socket. It could be that wires there are not connected with the socket or they are burnt out thus no connection.
Dec 20, 2010 | Electrical Supplies
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
Belt Lube sign appeared. So I lubricated the belt but cannot reset as stop button on keypad not working. Tried warming up with a hair dryer as well.
You probably have keypad failure since we don't know the make & model# of your unit it is better to contact the manufacturer directly and get the proper guidance & parts.
Jun 27, 2010 | Exercise & Fitness
My kenmore dishwasher, model 15822, just stopped working. The quick rinse light is blinking. The only other buttons that work are the pots & pans light which blinks when pushed, and the cancel button...
These are known to develop sticky switch contact pads. They stick in the contacted position and stifle the panel. Sometimes heat can be applied with a hair dryer to release them and make the unit function again. This is more than likely a temporary fix. New panels are available for about $165 to $200.
Jul 16, 2009 | Kenmore Dishwashers
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Kenmore Elite HE3
replace the power control board
Jan 21, 2008 | Kenmore 82822 Electric Dryer
Babylisspro Pro Babttw5586 Tt Tourmaline Titanium 5000 Dryer Logo
Top BaByliss Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a BaByliss Electrical Supply Expert? Answer questions, earn points and help others
