Question about Samsung SCH-U310 Knack Cell Phone
My phone freezes at verizon - Samsung SCH-U310 Knack Cell Phone
My phone is a Verizon Moto G , it sometimes freezes the apps, and then it turns off by itself. When I try turning it on it wont work, then i hold the power button and it vibrates, and take a while to
Panesha
Try running the phone in safe mode. To do this. Press power button then when power down appears. Long press power down option. It will ask if you want to boot into safe mode. Select ok the it will reboot in safe mode. Use the phone in safe mode for 24 he's to see how it works. If it works better, then there is a third party app you installed on the phone that I'd causing freezing.
Mark
Motorola Support
Nov 13, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
Tip
Verizon LG DARE Screen Freezing
I had been having trouble with my cell phone freezing if I did not receive an incoming text or call right away.
I was sure that I was just ready for a new phone even though I had finally just begun to like it.
(Before anything... remember to always check your lock feature.)
My daughter was upgrading to a blackberry when I mentioned the problem I was having with my phone and they told me that I could upgrade my program on my phone at no cost. Whatever they did, fixed the problem! You have to go to a Real Verizon Service Center that has the equipment but it will fix the problem!
on Jul 25, 2010 | Cell Phones
Lg chocolate freezing mid text
My LG Versa kept freezing up too...Call Verizon and have them tell you what software version is on your phone currently. I then took took it to the Verizon store and had it 'flashed' because there was a newer version for mine...it took about 25 minutes...worked fine...no more freezing up.
Oct 23, 2009 | LG CHOCOLATE VX8500 Cellular Phone
New blackberry phone - verizon...will freeze and can't continue typing in text. you can go to another screen such as phone key pad, but can't type in any numbers
blackberry as most phones come with niggles , sometimes you just need to remove battery for a couple of mins then try again , if symptoms persist take it back
Oct 13, 2009 | Verizon Communications BlackBerry Pearl...
KEEPS FREEZING WHEN MAKING CALLS PHONE FREEZES. WONT TURN ON ALL THE TIME AND ONLY WILL STAY IN WORKING OPERATION FOR A FEW MOMENTS AT A TIME THEN HAVE TO REMOVE BATTERY AND TRY TO TURN O;N AGAIN SOMETIMES...
This is a known software/firmware bug for the earlier versions. You should contact Verizon, explain the problem and request a software update under warranty. They might even swap phones to fix it ...
Aug 17, 2009 | Verizon Communications G'zOne Type-V...
My phone freezes
Your firmware is most likely corrupted. Backup your data as best you can and take it to a Verizon store (if your service provider is Verizon) and tell them about the problem and to update the phone. Also take out any MicroSD cards and try to use it, if there is any of those inside.
Sep 14, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Verizon razr v3m freeze
That is a software issue. You need to either contact motorola or verizon regarding that issue. This is a known problem with their phone and they never fully resolved the first batch of the Razor freezing issue.
Sep 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Vx5300 Freezes
Here is the cure:
http://slashdown.wordpress.com/2008/02/05/fixing-lg-vx5300-freezing-problem/
Jan 07, 2008 | LG VX5300 Cellular Phone
Verizon Razr freezes
emptied your text messages lately? this used to be a problem with the old v3c and verizon.
Aug 22, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Samsung SCH-U310 Knack Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
