Question about Panasonic PT-61LCZ70 Television
Tv screen is dark
The screen is hard to see. the lamp and brightness are all the way up.
3 Suggested Answers
SOURCE: my picture is dark and have changed the brightness
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
Posted on Jun 30, 2009
  • 382 Answers
SOURCE: tv screen is very dark after turning brightness all th way up
You bulb is shot. They are expensive, time to get a new plasma.
Posted on May 04, 2010
My tv's screem is little dark
Hello
If you set the lamp mode to LOW POWER, each time you turn ON the TV the lamp will start out at HIGH BRIGHT mode, but will switch to Low Power mode after a short period of time. You may notice a change in screen brightness when this happens. This is not a malfunction.
Just check whether you have selected this mode. Go to its user manual [P57]. All details are there about the lamp brightness settings. If it is not set to Low Power and still you get a dim picture, the lamp may be weak and has to be repaced. OK.
Nov 23, 2011 | Toshiba 65HM167 65" Projection Television
My Sony Trinatron has suddenly displayed a dark screen on all channels. You can see the picture but looks like it's nightime. I've tried ajusting the brightness but no result.
does the TV bring out sound even as the screen display is dark?
Problem should be from the TV lamp/bulb. When a TV bulb/lamp is dying, it makes the pictire on the screen become dark and very hard to see.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Dark Picture
Get a lamp ordered asap. It won't be long and you are going to need it. You lamp is on it's last leg.
May 16, 2010 | Mitsubishi WD-65731 65" HDTV
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust...
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Feb 04, 2010 | Philips Televison & Video
I have a Samsung 42" DLP. During the daytime I can hardly see the people and definition on the screen. It is all very dark. Nightime is better.
check your video settings there are 3 or 4 usually that all have various levels of brightness, it may be set to one of thelower ones. or you can go into tv menu and try kicking up the brightness. if no luck the lamp may be failing if not recently replaced they begin to make screen darker before they fail.
Jan 23, 2010 | Samsung DLP HL-P5663W 56" TV
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
We have 2 problems....dark screen/bright light on right side
Replace the light engine. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | Samsung HL-S5087W DLP TV
Panasonic PT-61LCZ70 Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
