Question about Canon Office Equipment & Supplies
Squeaking noise There is a sqeaking noise on our canon copier model # 1RC5185 machince. Sounds like a hamsetr running on a sueaky wheel. None of our canon techs can fix it.
SOURCE: squeaking noise in steering wheel
check your CV joint
Posted on Mar 30, 2009
greenspan
  • 1734 Answers
SOURCE: During neading machine makes squeaking noise, sounds like bearing
Look here, they have the manual for download.
Posted on Apr 09, 2009
dragonsthatk
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
  • 62 Answers
SOURCE: Squeak when turning steering wheel at low speed
Would it possibly be a power steering belt. i would have to hear it but this is most likely your cause of noise. Mike. Rate 100% please.
Posted on Sep 19, 2009
Controlfrk
  • 304 Answers
SOURCE: Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Posted on Sep 20, 2009
Squeaking noise right front ?
not sure what type vehicle we're talking about here, although you can lube up the rack and pinion or grease up your upper, if so equipped, and lower ball joints.
Oct 06, 2017 | 2000 Jeep Grand Cherokee
I'm getting clunking noise out of the front drivers side and a sqeaking noise.
noise when you turn? cv axle
noise going stright AND sqeak- strut
May 27, 2011 | 2003 Chevrolet Cavalier
When we press start to print a document it makes a squeak noise continously until the project is done. What is wrong?
sqeak noise usually indicates that the rollers need replacing or maintainace required --most likely the fuser assembly kit needs replacing (includes rollers & fuser)
what is the printer model ?
Nov 14, 2010 | HP Office Equipment & Supplies
Sep 19, 2009 | 2002 Toyota Avalon
Sueaky front wheel
It could be a number of things. First check your brakes for any rocks or excessive dirt. Second, check to make sure you are not in need of new brake pads. Brake pads are equipped with a tab that starts making noise when its time to replace your brakes. Third, have the bearing checked. Once the bearing get excessively worn they will start making a squeaky sound. Also have the shocks checked. the bushing worn out in shocks can also cause the noise. The best bet is to have your local mechanic inspect your front end for any wear. Once he does this, he can compile a list of parts that need replaced. Then you can replace or fix it yourself.
Aug 04, 2009 | 1996 Jeep Cherokee
Front end squeaking possible rotor rubbing something.
Have you checked the metal clips that olds the brake pads in the front galiper bracket. They usualy rust, break loose and come in contact whit the disc, creating a squeaking noise. Those should be replace since they are needed for the brakes to work properly
Jun 24, 2009 | 2007 Buick Rendezvous CXL SUV
FRONT END SQEAKING
worn out strut tower bearings.
Apr 13, 2009 | 2006 Dodge Sprinter
Squeaking noise from front end in cold weather
Bad ball joints. check out front end and make sure nothing else is bad. Good lucka nd thanks for using FIX YA
Mar 03, 2009 | 2002 Oldsmobile Intrigue
Squeaking noise from two front tires on neon 2002 when driving
hi..the reason to this problem is your wheel
bearings.you need to check out the bearings.
This could be the problem for the loud noise.
thank u..
rate me..
Feb 28, 2009 | 2000 Dodge Neon
14 people viewed this question
old marine
old marine
