Question about Emerson EM2516 Phone
Can not get dial tone
Need manual to describe functions of buttons.
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
Model no. 26928ge2-a need to change from tone to pulse
Press and hold the program button until you hear a beep.
Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
Press the program button again. You will hear a confirmation tone.
The above is from the fourth column of the manual at
http://www.home-electronics.net/USER-GUIDES/26928_DOM_ES_CL_IB.pdf
Sep 09, 2011 | GE Lands Phones
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
HOW TO USE RECALL KEY OR HOW TO USE THE REDIAL FUNCTION
Don't confuse the two. In most systems, the RECALL button gives you new dial tone on the line you're currently on, and the REDIAL function will dial the last number dialed or a saved number.
Since you're asking about a phone and did not list the SYSTEM, if you set has Last Number (LNR) or just redial, when you press the button, it will either try to use the last line dialed, or you may have to select an outside line and get a dial tone, then press the LNR button. It will dial out. If you press the RECALL button, it will drop your present call and give you new dial tone without having to hang up, pick up the handset, and select a line. You may actually have to press both buttons to effect a LNR sequence.
Carl
Aug 18, 2010 | NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
I have a GE cordless phone model # 26928GE2-D and would like to know how to change the setting from pulse to rotary dial
The phone is pre-set for touch-tone use. To set to tone or pulse dialing:
1. Press and hold the Program button until you hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the Program button again. You will hear a confirmation tone.
For more details, kindly download the instruction manual by clicking this link
You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Also, the manual has very small print, so kindly magnify it by using the "+" button in the Adobe PDF reader window.
Hope this solves your problem. Thanks for using FixYa
Mar 25, 2010 | Uniden Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Oct 24, 2008 | Plantronics CS70 Wireless Headset
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Emerson EM2516   Phone Logo
75 people viewed this question
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
