Question about Frigidaire Affinity AEQ6000WH Dryer
How to error test my dryer - Frigidaire Affinity AEQ6000WH Dryer
Wire testing on Electrolux E63 error.
I appreciate your post, Tim Davis!
From what you have described your Electrolux dryer is displaying an error code "E63". I understand that you have performed several tests on different electrical components within your dryer. I see you wanted to further test the wiring and I would recommend having a professional technician come out to perform a diagnosis. Since you have completed many tasks there are no instructions I was able to locate that provide further wire testing on your dryer. Best of luck! -Matt
Jan 07, 2015 | Electrolux Dryers
What does error code E68 mean?
Hello Friend, this is Z. Thank you for your question!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's perform Key Test to determine which button is at fault by entering "Function Test Mode". To perform the "Function Test Mode", doing the following:
Press and hold the START and CANCEL button at the same time for roughly 10 seconds. The stuck key should blink.
Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis.
If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area.
Hope this helps!
Jul 27, 2014 | Frigidaire GLGQ2152ES Gas Dryer
Frigidaire affinity dryer error 68 and hot to touch
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
Jul 26, 2014 | Dryers
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
May 22, 2014 | Electrolux Dryers
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.
3.Press the "SIGNAL"button.
4.Press the "DELAY START"button.
5.Press the "SIGNAL"button.
6.Press the "DELAY START"button.
Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Sep 25, 2009 | Electrolux EIED55H Dryer
GE Dryer error code E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
Mar 16, 2007 | GE DBVH512EFWW Dryer
Frigidaire Affinity AEQ6000WH Dryer Logo
24 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
