Question about Minolta Di151 All-In-One Laser Printer
Error code C 13 is flashing - Minolta Di151 All-In-One Laser Printer
  • Minolta Master
  • 6,359 Answers
What mode machine?
Posted on Jul 04, 2014
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
What is error code E:62:13
No idea what that code means but I have seen a lot of postings about it. It seems to originate from being dropped, is expensive to repair, but is often solved by actually whacking the camera with ones hand.
May 31, 2014 | Sony Cyber-shot DSC-H9 Digital Camera
Philips 42pf7320 10 has flashing led 13 times error code d5vl
your set is a 42pf7320/??. very inportant in you case. The chassis is a LC4.9E AA. error 13 relates to IC 7D03 (HDMI panel link receiver).
Jan 07, 2014 | Philips 42 in. Plasma TV
I have a paloma tankless water heater, ptg-42pvn. It was flashing, C4, 13 and now it only flashes -0, 13 and will not even turn on. Tried to reset it by unplugging it and it only flashes -0, 13 even...
Multiple error codes can mean different things, including bad PC board.
C2 13 might be the oxygen sensor. -0 and no operation indicates bad board, but other things might be notched into same problem like loose connections.
Error codes are starting point for troubleshooting.
Before calling service technician, open following link for Rheem-Paloma troubleshoot resources including Rheem chat.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Error code 13 what does this meen ?
I believe it Means to "Clean Filter"
If that doesn't work Call Sharp Toll Free 1-800-237-4277.
When prompted push for Air Conditioners.
They will help you free of charge.
Hope that helped
Please Rate Me
Thanks
George
Apr 27, 2009 | Sharp Heating & Cooling
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Error code 13 on my car stereo
I visited VR-3.com and found the following in the manual: Problem: MP3/WMA Files on the USB/SD flash memory do
not play.
Answer: Flash memory is formatted as NTSC.
Format the flash memory as FAT or FAT32.
The files have Digital Rights Management(DRM).
If the files you are attempting to play were
purchased online, they may have Digital Rights
Management, this unit is not DRM compatible.
You may want to call VR3 at (800) 445-1797 and inquire about that specific code just in case though the answer above was not given as "error 13" I just made an educated guess based on the problem given.
Jun 29, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Error light
There is an error code that flashes on front of TV. which is in this case an error 7 which is power related. Also there is a gree LED on the power supply that will flash an error code also. If u look on the power supply U will see a list of numbers 1-13 which list the error codes and what they mean.Usually if it flashes 1-9 its usually cheaper to just buy another TV. because the Power supply , Y-main, X-main will probably run $300 plus core charge.
Mar 27, 2008 | Philips 42PF9630A 42 in. Plasma Television
Minolta Di151 All-In-One Laser Printer Logo
22 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
