Datacard sp75 - heater /thermocouple error. can not print anything due to this error. recently pulled the laminator with a stuck card badly burnt, could this be the cause and how can i solve it?
I have datacard sp 75 card printer which have been working well for long but of late it has developed an error (heater problem in laminator L1 OP 0164). It can hardly print any card as the error keeps on popping up once I send a print job. What can I do urgently as I have a lot of cards to print?
2 Suggested Answers
SOURCE: heater error in Sp75
tenia el mismo problema, se soluciona verificando que el "ribbon" del laminador este colocado de la manera correcta y la cintilla blanca que tiene pegado uno de los extremos del "ribbon laminador" este pegada al mismo, ya que este funciona como un sensor, si este se despega, la impresora enviara una señal de error y no laminara
Posted on Aug 26, 2009
HOW DO I DISASSEMBLE TO CHANGE LAMINATE POWER BOARD
try utube or go to manufacture website for instructions.
Dec 05, 2014 | Datacard SP75 Plus Color Card Printer (P/N...
Lamination Problem
You have to go to printer driver, see the general settings and put more darkness(normally it ranges from 0-20, it should be set at 10. Try puting the darkness at 11,12,13, etc until it laminates properly. Don't forget to put back the setting when printing ymcko, or you will burn ribbon.
If the head that prints color is the same that laminates, then you should be cleaning the head after use.
Jan 17, 2014 | Datacard SP75 Plus Card Printer
Password advanced user diagnostic print tool datacard sp75
The advanced user password for the SP75 Plus diagnostics is 926918
Jul 09, 2012 | Datacard SP75 Plus Card Printer
My datacard printer ribbon is supposed to get upto 500 images, but it is skipping every other color series so I am only getting 250 images
Every time you open the printer, it advances CMYK panel 01 to position the print head.This can cause loss of ribbon. Avoid opening the printer to the maximum you canoptimize your prints.
Jan 20, 2011 | Datacard Group Datacard SP75 Color Card...
My datacard group SP75 color is printing cards with a white line all across it_
First, try to determine if it is printing a white line, or if an obstruction is possibly scratching the card surface; if it is an actual white line, then you probably have a pixel out in your printhead. Your printhead must be replaced.
Apr 15, 2010 | Datacard Group SP75 Color Card Printer
Datacard SP75 Plus not responding
I have error code h 3 , 7 printer xerox workcenter xd155df
Feb 12, 2010 | Datacard Group SP75 Color Card Printer
Running "test" cards on the SP75 Plus.
Is the test card meant to the laminator heated?
If so, you should be able to set the laminator time out from 30 minutes to 5 hours.
This is done through the front panel under the configuration menu.
Hope this helps
Apr 27, 2009 | Datacard Group SP75 Color Card Printer
Air bubbles in laminate
Do you have a dual lamination station in your printer? How old is the printer?
There may be contaminates on heated platen that is causing the bubbles. I would go into the printer settings and try various settings such as LAM1-BOTH SIDES and LAM2-NONE then LAM1-NONE LAM2-BOTH SIDES to isolate the issue
Feb 11, 2009 | Datacard Group SP75 Color Card Printer
Heater error in Sp75
Sounds like either the thermocouple or the heater went out. Was this the error code?
OP-01604 Thermocouple problem in L1 laminator
The comments in the service manual states:
- Check the thermocouple wire for damage.
- If the thermocouple was recently replaced, verify that it is not installed backwards
- Verify that the thermocouple connector is not unplugged or plugged in backwards
I would probably order a replacement part, call in your local DataCard service representitive or send it to DataCard for repair.
Oct 01, 2008 | Datacard Group SP75 Color Card Printer
Uper Duplex not holding card in place
early model sp75s have that type of problem. It can normally be fixed by replacing the clutch and duplex board. Very easy to replace. Be sure to be aware of the clutch spring when removing the duplex tray. Use the lower duplex assembly as a guide.
Jul 02, 2008 | Datacard Group SP75 Color Card Printer
54 people viewed this question
k24674
jasbo
jasbo
