Question about Panasonic CT-32HXC14 32" TV
My panasonic says #10801 on the front
I have lost the manual,  I have no idea how to set the remote -  the cable
hs not been hooked up for two years.  Now we are ready for the t.v.
and I can't get it programmed..... help...
  • Anonymous Mar 02, 2008
    We do not have a manual either - we cannot get video on Component 2. HELP
    It is a 55" Projection TV
Sounds like it is in 1080i mode and you are inputting another type of input. the manual is here on this site for downloading. if you can't find it here let me know and I can send you the pdf of it .you need to go thru the manual and set the input for the same mode as the signal you are feeding the set.
Posted on Jan 18, 2008
HAVEING ISSUES WITH panasonic th-p50x10a no remote and its stuck on analog
You are going to need the original remote or a magic wand, whichever is less expensive (just kidding about the wand)---you need the original remote, should not be too hard to find or too expensive.
Apr 08, 2012 | Panasonic Televison & Video
Panasonic HDTV 10801 BBE TAU
Unplug it for a few seconds and
plug it back in if this doesn't
do it the call in a technician
may be HV or PWR Sply problem
Nov 29, 2007 | Panasonic CT-32HXC14 32" TV
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
Lost manual need set up instructions and code for Panasonic TV
The manual for your URC-3021 is located at .
Pgs. 8-10 cover device programming, code searches, code checks and, according to Pg. 19, the codes for a Panasonic TV are: 0051, 0250, 0650
Mar 19, 2011 | One For All URC-3021 Remote Control
Panasonic DMREX85EBS recorder upscaling problems
Check the HDMI settings and your TV specifications. Press Functions on your remote and go to Display (up/down arrows). Press Enter. Go to Connections and again Enter. Then HDMI settings and Enter. Look for HDMI video settings. If the setting is automatic, the unit sends the output it believes is best for the TV. You will notice that the compatible video outputs are the only ones available for selection. (A new cable may be worth testing.)
I hope this helps.
Jul 13, 2010 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Remote won't work
According to page 15 of the manual, you should "Press and hold [ENTER] and the indicated number button at the same time for more than 2 seconds" This will work for SET 1, SET 2, etc. If you have lost the manual for the DVR/Remote you can download a copy at
Jan 02, 2010 | Panasonic DMRES15 DVD Recorder
Initial setup of tv with out remote control
You probably will not have access to all features from the front panel but you can get an original replacement remote here:
Panasonic remote
May 22, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Panasonic CT-32HXC14 32" TV Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
