Question about LG WM1815CS Front Load Washer
Broken spiderHi there, I have a LG washing machine model wm1815cs and I'd like to know where is the main board located and how do I reach it to replace. Thanks!
5 Suggested Answers
milten1
  • 1304 Answers
SOURCE: Replaced the thermistor on the lg washing machine
sometimes these
have lockouts,
try reseting the eprom
there is two ways,,,
unplug it for ten minutes
or push and hold the pause button for 10 secs
depending on your model this should work
but not knowing the exact model i cant be more help ful but i do hope this saves you 200
Posted on Oct 19, 2009
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
SOURCE: I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
Posted on Jul 10, 2010
  • 298 Answers
SOURCE: I have a LG Direct
you can go to appliancerepairplanet.vstore.ca to get a sevice manual on that and help with that.
Posted on Dec 15, 2010
Washer not draining
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Oct 12, 2016 | LG WM1815CS Front Load Washer
Front loader. Why isn't display working?
If there is mains supply reaching the main power PC board, then the board needs replacing.
Otherwise check the fuses and inline protection systems in order for the supply power to reach the electronics.
Nov 17, 2015 | LG Washing Machines
My LG wm1815cs turns itself off 10-20 minutes into a load of towels. I think it may be weight related but I am not getting any error code
Certain machines have specification, which the user must follow, if you do not adhere to, the machine will not work. if load is one of them, stick to regulated weight it can handle.
Feb 22, 2015 | LG WM1815CS Front Load Washer
Not the drain pump...
you may have inadvertently left a switch disconnected in the frame or the drum area..so when it reaches that part of the cycle, it just stops because the circuit is open..
Apr 11, 2014 | LG WM1815CS Front Load Washer
LG Front Load WM1815cs Makes loud noise when spinning. Inner tub is loose and seems to bounce making loud noise. Is this more than a bearing problem?
The outer tub and the bearing will need replacing as by replacing only the bearing will be a short lived repair as it will go the same way.
Aug 25, 2013 | LG WM1815CS Front Load Washer
How to replace the drain motor
try checking the filter or coin trap before you try to replace the pump. on an LG replacing involves removing the front of the machine, pretty big job if you don't know how.
Jan 23, 2012 | LG WM1815CS Front Load Washer
I have water flowing out of the soap dispenser on my front load model wm1815cs. How can I fix it.
Sounds like the dispenser is clogged with soap residue -- needs cleaning. First, try just pouring copious amounts of water in it and running something akin to a pipe cleaner down through it.
If this doesn't work, let me know.
Charlie
Jan 09, 2011 | LG WM1815CS Front Load Washer
LG WM1815CS Washer An item was recently washed in my washer with sharp edges. Part of that item broke off and I can't find it. Also, the rubber seal on the frame of the door is now slashed (underneath the...
Have you checked the filter to see if the item has been trapped there? Is so you can remove it and then replace the rubber seal as you describe - not too difficult. I would recommend not using the machine with a broken seal as the machine will probably leak.
Jan 04, 2011 | LG WM1815CS Front Load Washer
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
LG WM1815CS Front Load Washer Logo
23 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
