Question about Dryers
Have a h3 elite gas dryer that stopped putting out heat. Ran diagnostic on it (after going through all the checklist issues on the tech sheet and finding nothing wrong) and got a code to replace the
Kenmore Elite h3 gas dryer producing no heat.
duby1990
  • 367 Answers
SOURCE: Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Posted on Nov 21, 2008
  • 175 Answers
SOURCE: Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Posted on Jun 09, 2009
SOURCE: Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
  • 135 Answers
SOURCE: Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Posted on Aug 27, 2009
Testimonial: "I replaced both works great thanks for the conformation."
  • 2183 Answers
SOURCE: Kenmore Elite Sensor Smart Gas Dryer - no hot air
unplug the dryer,if you haven't cleaned out the dryer check the thermal fuse located on top of the blower wheel housing,remove bottom panel,then remove lint filter,now remove the duct that the lint filter slides down into,now you'll be able to check the thermal fuse located on the top right side of the blower wheel housing,there's also a thermister there too,the fuse is the one on the left,part number 3392519 or 3390719,remove one of the wires and read it out with your meter.also while your in there vac out the inside of dryer,if you have a shop vac put it on blow and blow off all the lint that's built up on the motor and you can also blow the lint that's in the back of dryer forwards so you won't have to pull the drum,if you have a long run on the vent line from the wall to the outside blow it out with a leaf blower,if there is any blocks in the vent line,the duct or lint inside the dryer you could have a fire so this should be done every year,now if the fuse is good you gonna have to read out the ignitor,the sensor and the gas coils,if you have parcial heat it's definetly the gas coils,when they heat up they stop working when they're bad,if you need anything else let me know,so check the thermal fuse first,then the ignitor,sensor and coils,if they are good check to see if power is coming down to fuse and ignitor,you have a computer board on this dryer but most of the time it's the fuse and a dryer clean out
Posted on Dec 17, 2009
My frigidare affinity dryer is only starting on delicates and touch up, can you tell me why this is happening?
Hi.
If machine runs only in low heath cycles, then there is a problem with timer control, low heath selector, or heating assembly (cycling thermostat).
The first thing to do would be locating the tech sheet. The sheet is tucked inside an envelope located inside the control panel assembly. In the tech sheet you will find instructions to run a diagnostic cycle. The diagnostic cycle will return an error code that will help locating the fault.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and touch START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
Regards.
Ginko.
Nov 19, 2011 | Dryers
My frigidare affinity dryer is only starting on delicates and touch up, nothing above that
Hi.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and press START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
Model 110.78082701 F40 error code what does it tell is bad?
F40 is a error that appears between the machine control and the motor control when communication becomes lost. I had this same issue. My dryer would run and heat up but then stop and give me the f40. I measured all thermisters and everything was in range. The tech sheet stated that I needed to buy a new control board and I did. Same problem.
The solution was a loose connection on for p4. I took needle nose pliers and squeezed the connector to make it fit tight on the board and everything is working now.
Bottom line, expensive dryer with cheap connectors.
May 11, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
F-40 code?
Apr 06, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Stops running and/or won't start
sounds like the little control board in the console either two screws on right and left side and lift up console or the screws could be on the backside there will also be a tech sheet in there to coach you thru diagnostics
May 11, 2009 | Dryers
Kenmore Elite HE3 Gas Dryer no heat
Verify the glow bar ignitor is working. Also ohm it to specs before you replace a gas valve coil.
Mar 02, 2009 | Kenmore Dryers
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore Elite Oasis Electric Dryer, Model #110.6708*, 6709*
ck behind bottom panel if it has one or in console if it is mounted on top rear for tech sheet with codes (can tell from image where your console is ..sorry)
Jul 04, 2008 | Kenmore Elite HE4 Electric Dryer
Gas dryer - no heat
There should be a tech sheet in the console. You probably have a blown thermal fuse. It is mounted in the air duct coming from the blower housing and has two blue wires going to it.
Post back with the complete model number from the decal inside the door if you cant find the tech sheet and I will see what I can come up with.
Thanks/Mike
Nov 05, 2007 | Dryers
Dryers Logo
19 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
