Question about Sharp Atomic Weather Station Alarm Clock
Weatherstation sharp spc344 inside temp has been stuck on 71 degrees for weeks. Outside temp shows correctly. what to do?
Outside temp. shows IF and inside temp is stuck at 58 degrees. What do we do.
change the batteries in both units. Station first and then the outside monitor.
Nov 14, 2015 | Cars & Trucks
My termostat is set on 71 but the temp inside says 76 while it is 100 outside is that normal?
rule of thumb is that an a\c unit will keep a house 20 degrees cooler than outside air temp
Jun 19, 2010 | Heating & Cooling
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
Some odd electrical things are going on with my grandfathers Lincoln. the one I'm stuck on is the outside thermometer. Recently it has been in the 90's and even a week of 100+ degree's. The vehicle outside...
Its the ambient air temp sensor. This is usually located up in the front of the car behind the grill attached to the center post that the hood latch is mounted to. It is a 2 wire connector, unplug, replace, replug. Temp will take a few minutes to "calibrate" and all will be well.
Aug 07, 2009 | 1994 Lincoln Town Car
Outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Jul 15, 2009 | La Crosse Radio Controlled Atomic Clock
Sharp SPC344
You might need new batteries in the indoor readout unit, even though it appears to work normally. I just had the same problem and this fixed it. I know this is 2 year old problem but this might help someone else. Len 8-7-11
Mar 10, 2009 | HTC Touch P3452 Smartphone
Outside temp stuck on -40
when its at -40 usually its because the ambient temp sensor is not sending the proper signal to the controller.. it may just be disconnected.. the sensor it behind the grille.. it has a 2 wire connector to it ... itf its connected it may havea broken wire from body damage in an accident... its rare that the sensor fails..
Jan 30, 2009 | 2001 Chrysler Town & Country
Sharp Atomic Weather Station Alarm Clock Logo
32 people viewed this question
Top Sharp Measuring Tools & Sensors Experts
 Paul
Paul
Level 1 Expert
rhodesworks
Tom Chichester
Are you a Sharp Measuring Tool and Sensor Expert? Answer questions, earn points and help others
