Question about Zeiss Humphrey 740 Visual Field Analyzer
Seuss Humphrey 750 error message [dim room light and press restart ] what do I do in this case
How did dr.seuss get dr in his name
Dr. Seuss's real name is Theodore Seuss Geisel. Named Theodore after his father, the Seuss came from his mother's maiden name. Growing up, Theodore was more commonly called Ted.
So, if Dr. Seuss's true name is Ted Geisel, then how did the name "Dr. Seuss" come about? Well, some could say the beginnings of this famous name first came about while Ted was attending Dartmouth College.
As punishment for waking up his landlord while throwing a party, the Dean of the college made Ted resign as editor of the Jack O'Lantern, the school's humor magazine. In order to keep editing, writing & drawing cartoons, Ted Geisel would sign his name as Ted Seuss or sometimes just, Seuss.
So, we found out where "Seuss" came from. But, what about "Dr."?
Ted added the "Dr." while working for the magazine publication, Judge. Assigned to a regular cartoon feature about animals called "Boids & Beasties", Ted signed his name Dr. Theophastrus Seuss to sound more professional.
Soon, Theodore Geisel was signing Dr. Seuss on all his work (saving his real name for the great novel he would write someday).
Mar 03, 2015 | Miscellaneous
CAN THE LIGHT BE TURNED ON IN THE ROOM WHERE THE TESTING IS DONE?
Yes it affect all tje instrument calibration when it is turn on, and when you have patient test the result is afected because the patien has light for the bavk and he is not able to see all the diferents type of lights
Sep 18, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
Mar 27, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
then select 4:PlotsOff.
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
How to use remote on ceiling fan id m8crl 103
Press the light button and bottom green button at the same time the lights dimming feature will work!
Mar 09, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
I keep getting a "Scanner Failure" error message every time I try to make a copy. I have tried all the trouble shooting the HP manual suggests but still no luck. Anyone know how to get rid of this...
This series of HP all-in-one units have a common problem that, over time, the exposure lamp. which is florescent, goes dim. The scanner looks for the right amount of light, and if it doesn't see it, it gives you the scanner failure. In some rare cases, you can dismantle and clean the mirrors and lens in the scanner, but most of the time it doesn't work.
There are no parts available for this unit.
Oct 18, 2010 | HP PSC 750 All-In-One InkJet Printer
Error message:
If you were trying to do paired-variable statistics the lists fo not have the same length, Check you lists and make sure they have the same number of elements.
If you were trying to draw graohs and you got this message, then you should turn StatPlots OFF. To do so press
[2nd][STATPLOT][4:PlotsOff][ENTER][ENTER]
Press [2nd][CATALOG] C. In the list of commands that appear scroll down a bit to reach ClrAllLists. Point to it and press [ENTER][ENTER]. Calculator displays Done.
Restart you graphs.
If you were using matrices, the dimensions may be incompatible for the operation.
If you had spelled what you were doing prior to the error message, I would not have had to guess.
Hope it helps.
Nov 13, 2009 | Texas Instruments TI-83 Plus Calculator
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Zeiss Humphrey 740 Visual Field Analyzer Logo
85 people viewed this question
Top Zeiss Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
