Question about Brookstone Audio Players & Recorders
Fuse blown in Brookstone stereo - Brookstone Audio Players & Recorders
Speaker will not turn on when pugged into power pack.
speaker may be fuse inside, disassemble and check for blown fuse
press the helpful button and follow me on fixya for more tips
Feb 09, 2016 | Brookstone Big Blue Studio Bluetooth...
2004 sunfire
The best advice for a quick solution is for you to look at your fuse box. It should indicate right there what fuse is for the radio. If not, look at all of the fuses and replace the one that is blown.
Aug 31, 2014 | JVC AM FM CD DET FACE CAR STEREO
I need an AC adapter for outdoor speaker(497362p ) Whats the output V. requiered? Where I can buy it ?
Hello
The AC adaptor for your Brookstone is for [12V 2.5Amps]. You can get it from most of the electronic sparepart shops at your town. OK.
Jul 24, 2011 | Brookstone (497362) Main / Stereo Speaker
Radio want come on
on the driverside plastic panel beneath the steering wheel will be a fuse panel. fuses are forks of metal partially covered in plastic. they are colored. on the back of the panel are diagrams of fuses and the system they protect. find the one named stereo, and pull it out. through the plastic coating you will see a wire. if the wire is broken the fuse is blown and your stereo will not come on. if the fuse is not blown there is also another fuse located in the rear of the stereo component. reaching this one is difficult however and instructions may vary between cars. check these first. if neither is blown either your stereo component is fried or you have wiring issues.
Feb 11, 2011 | 1992 Buick Roadmaster
I just need to get an owners manual for a Brookstone Acousticlear stereo model #SLCDV3.0. Thank you
hit the thingymajiggermabob inside of it with a hammer than it shall work if not get a new one problem solved
Dec 18, 2010 | Brookstone AcoustiClear Desktop System CD...
How to check for blown fuse radio will not light up turn on
There should be a fuse plugged into the back of the stereo, remove the fuse and check the element of the fuse for being broke in half. Also, check the fuse in the car that supplies power to the stereo.
May 14, 2010 | Kenwood KDC-419 CD Player
Stereo wont turn on
the fuse might of blown take it off and check the fuse
Nov 10, 2009 | Cars & Trucks
37 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
