Question about Frigidaire AEQ6000ES Electric Dryer
Aeqb6000es2 dryer wont heat and says ad - Frigidaire AEQ6000ES Electric Dryer
2 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: my dryer has a loud squeaking noise it is a frigidaire dryer model num AEQB6000ES2
Hello there and welcme to fixya
This is a fairly common problem with these dryers
please check each of the following you will probably have to remove the outer shell to get axcess to these parts listed below
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Posted on Dec 24, 2011
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
Ad error code
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
AEQB6000ES2 dryer wont heat
There are 4 things that can cause this issue: 1. Thermal Fuse (Protects the dryer from overheating and fires) if this is blown, the drum will still turn but you will have no heat. {Cheapest Fix} 2. Heating Element Assembly {Third Cheapest} 3. High Limit Thermostat (if this is stuck OPEN, the dryer will not heat) {Second Cheapest but rare issue} 4. Main Control Board (Check all the other parts first as this is not cheap and there is no way to test it, if the other parts do not fix the issue, replace this. Not a common issue but can be a manufacturer defective item)
Feb 27, 2013 | Kitchen Appliances - Others
My frigidaire dryer isn't heating up..and after 20min.. is displaying AD??
Is this the only code you are showing...The AD indicates the dryer is in the Auto Dry cycle....You most likely have a blow thermal fuse...A faulty heater coil...You would need to break dryer down and test components with a meter.
Here is a tech sheet you can download...This will walk you thru the troubleshooting.
http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf">http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf
Mar 11, 2012 | Frigidaire Dryers
My dryer has a loud squeaking noise it is a frigidaire dryer model num AEQB6000ES2
Rollers
Dec 23, 2011 | Frigidaire Dryers
Displayed codes
Error code "AD" means air/automatic dry. This type of dryer has no thermo fuse which is a fuse like part that tends to break disengaging the heating element, there for the dryer has a busted heating element.There is no other go you should go for a replacement of your heating element. This solution will solve your problem.
Apr 18, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Mar 28, 2009 | Maytag MDG2706A Gas Dryer
Dryers Logo
29 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
