Question about 1992 Chevrolet Camaro Z28 5.0L Oxygen Sensor
How can my oxygen sensor on my Camaro v8 1992
  • 24 Answers
Need more information.
Posted on Feb 14, 2014
Oxygen sensors reading wrong but brand new
I;ve had that problem with an AUDI because I had the MAF disconected. Make sur that all sensors related to combustion and emission control are connected and check again. If not then your sensors could be bogus.
Oct 05, 2012 | 1996 Chevrolet Camaro
Code p0300 1998 chevy Camaro. Car does not turn over.
None of these codes by themselves will prevent the car from starting. I would look over the O2 sensor wiring. Maybe the harness is resting on a hot pipe. You can test the components--the sensor and both solenoid valves. Maybe there is a problem at the canister. Unfortunately, the canister and vent valve are atop of the tank, but you can still hear if the vent valve is closing when you apply ground to the white lead. The p0300 is the most likely code to affect starting. Are you getting sparks? If not, suspect the ignition module under the coils. I drive a 2000 Camaro, so I'm pretty familiar with this model.
Jul 23, 2017 | 1998 Chevrolet Camaro
What is a P 133 code on a 1998 Camaro indicating?
There is no code P133...that is not enough numbers. If you mean P0133, then that is "Oxygen Sensor Bank 1 Sensor 1 Slow Response". This is USUALLY caused by O2 sensor contamination. The O2 sensor itself is not responding as quickly as it should to changes that the computer makes to the injector pulse width.
Sometimes the O2 sensor is just plain worn out, however the engine should be checked for things like leaking valve seals (burning oil) or a leaking head gasket (burning antifreeze) that could be contaminating the O2 Sensor.
Please also review these articles:
Which Oxygen Sensor Is It?
What Else Could Be Wrong?
Aug 07, 2011 | Chevrolet Camaro Cars & Trucks
How do you install a oxygen sensor in a 97 camaro
you need to remove the old sensor from the exhaust pipe with a box wrench, and the new one will thread in... there is also a wire which is longer and has a clip that needs to be undone also. remember let some penetrating oil work the threads because it is more then likely heat bonded in.
Aug 23, 2010 | 1997 Chevrolet Camaro
Im getting to much fuel my 1992 camaro rs 5.0L 305 v8 TBI. its running real rich. ive replaced the cooliant temp sensor, throttle position sensor, fuel pressure regulator,spark plug and wires, distributor...
The precatayltic O2 sensors or sensor may by malfunctioning.These are the O2 sensors that tells the ecm to adjust the air fuel ratio according to how much oxygen content is in the exhaust.If for some reason it thinks to much oxygen content is in the exhaust it will tell the ecm to add more fuel.The post catalytic O2 basically is used to monitor the catalytic converter function and should not adjust any air or fuel. Is the check engine light on and are any codes presnt?
Jun 10, 2010 | 1992 Chevrolet Camaro
Po137/po157 codes no activity
P0137 / P0157-Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2) refers to the second oxygen sensor on Bank 1. P0137 means the O2 oxygen sensor's voltage remained low for longer than 2 minutes. This, is interpreted by the ECM as a low voltage condition and sets the MIL. Bank 1 Sensor 2 is located to the rear of the catalytic converter and should produce an output signal relative to oxygen storage capacity of the catalytic converter. This rear (sensor 2) sensor is less active than the signal produced by the front sensor. However, if the ECM senses the sensor is inactive, this code will set.
A code P0137 may mean that one or more of the following has happened:
Faulty o2 sensor Exhaust leak near the rear sensor
Plugged catalyst
Short to voltage on O2 signal circuit
High resistance or open on O2 signal circuit
Possible Solutions…
Replace faulty sensor
Repair exhaust leak near the rear sensor
Check for restriction in catalyst and replace as necessary
Repair short, open, or high resistance on o2 signal circuit
Mar 08, 2010 | 2000 Chevrolet Camaro
Where is the #3 bank 1 oxygen senser located on the exhaust system of my 1999 chevy s10 4x4 4.3 liter v6 pick up?
The oxygen sensor is located in the flow of exhaust and there will be two. the first is at the exit of the exhaust manifold where the head pipe attaches before the converter and the other is just after the cat converter.
Sep 10, 2009 | Chevrolet S 10 Cars & Trucks
How many o2 sensors does the 94 camaro have.
There is two(2) up top.Left-side of top engine.Right under the windshield level.The other one(1) should be on your right side of the engine,on the top.The other two (2) is in the rear,under the vehicle.One on both sides.
Jun 24, 2009 | 1994 Chevrolet Camaro
1992 Chevrolet Camaro Z28 5.0L Oxygen Sensor Logo
47 people viewed this question
Top NTK Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a NTK Vehicle Part and Accessory Expert? Answer questions, earn points and help others
