Wi-Fi is rapidly replacing wired LAN in homes and offices. This is the reason most high-end printers now come with Wi-Fi built into them. Now you can print documents wirelessly without attaching cables. However, before you print, you need to connect and configure your printer to print over a Wi-Fi connection. In order for the wifi to work, your printer and your computer must connect to the same wifi router or to an access point/repeater/extender connected to the same router.
1. Open Internet Explorer, on the address bar type 192.168.1.1
2. There's no username and type
admin on the password. If admin didn't work, use your own password.
3. When you have the Setup Page open, click on Wireless Tab, then click on the sub-tab Wireless Security.
4. There you can see the Security Mode. If the mode is set to WEP, the WEP Key 1 is your wireless key. If the mode is set to the WPA-Personal, the Passphrase or the WPA Shared Key is your wireless key/PIN.try this steps and fix problems let if you have facing this problems call
canon printer technical support Experts toll-free number 1-800-213-8289 for get online help.
Epson Wireless Printer Support Number 1 800 610 6962 Help
