Question about Sony Alpha DSLR-A350 Digital Camera
When memory card is inserted the camera wont work
Once memory card is inserted a red light comes on the right hand side and wont work
    Top Expert:
  • Sony Master
  • 6,702 Answers
You can insert CF memory and some memory stick cards when you use a special adapter. When you use a memory tick, make sure it is compatible, because the memory stick is the most incompatible memory card, if you have not the correct one.
When you use a CF memory card, check all contacts. Not one contuse pinn in the camera should be belt a little. Use a bright light and a loupe to check.
Posted on Feb 15, 2014
  • 17 Answers
SOURCE: Memory card
dear friend.
here its a problam in mem card or a sellaction of format try to fromat yr mem card in fat16 format and then try with this methord..
don't forget to vote me.. thanks advance.
jo_chinmay
Posted on Apr 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Camera won't recognize internal memory
copy all internal memory data on memory card and intialize camera by going in menu. after that try to format internal memory.
Posted on Jul 23, 2008
SOURCE: Camera won't turn on
There was a POWER button.Please press the button.The button will show GREEN.
Posted on Dec 19, 2008
fotomohamed
  • 321 Answers
SOURCE: after inserting memory stick, a blank screen comes up
camera card unlocker pin is broken
Posted on Jun 20, 2009
omtronixom
  • 172 Answers
SOURCE: red light nat bottom right side of camera
Its circuit fault and it might be for water logged or battery leakage water or at the time of transfer photo through USB
Posted on Mar 10, 2010
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
For some reason, the memory card got stuck,,i have tried in a very careful way to remove it, which i did.now everytime i switch the camera on,it works fine without the memory card,,however once i insert a...
first you have to check the card broken any side if not broken the try to format from setup menu.after that check if still problem then card problem or in side camera pin broken or tilt beacuse wrong way insert card in side.
Oct 23, 2010 | Samsung TL34HD / NV100HD Digital Camera
When a memory card is put in the camera a red screen comes up stating "CARD HAS WRONG FORMAT. Press ok to format card." When I press Menu/OK the window says, "Unable to format." I can't even get to the...
Hello Mr rtautwein .
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 02, 2009 | HP Photosmart M425 Digital Camera
    Have fujifilm finepix f40fd. protected card shows. wont clear
    just take out the memory card . there will be a small button or a panel like thing on one of its side. just move that to the other side i.e opposite to the current position of the button. re-insert the memory card and check it out...
    May 29, 2009 | Fuji FinePix A303 Digital Camera
    MEMORY CARD FORMATTING
  • May 19, 2009 | Kodak EasyShare CX7430 & EasyShare Printer...
    AIPTEK IS-DV2
    First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
    If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
    The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
    To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
    Jul 08, 2008 | Aiptek IS-DV2 Camcorder
    Memory card won't stay in
    dear dave how did you insert the memory ? it will only work in one way , the other way the memory card may be seated but infact it is not fully seated and won't want to goe further , Take out the memory card turn it around so that the label side is facing the other way and try to see if ti will fit in that way you wont have to push it hard just once light and than it will have to be in place
    Mar 15, 2008 | Nikon COOLPIX S200 Digital Camera
    Camera wont turn on, intermittent red power coming on
    This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
    If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
    http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
    Jan 08, 2008 | Fuji FinePix V10 Digital Camera
    Camera will not read memory card
    Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
    May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
    Sony Alpha DSLR-A350 Digital Camera Logo
    41 people viewed this question
    Top Sony Cameras Experts
    james laughton
    james laughton
    JonSnell Electronic
    JonSnell Electronic
    Are you a Sony Camera Expert? Answer questions, earn points and help others
