Hp g50 laptop
My HP G50 cant boot the window. ..i tested the RAM + HDD n replacing CPU but still cant boot the windows, its only start on the power n left the screen on black, some time its give an option to enter the bios settings and all settings are clear(default)
  • fahmi el-battashy
    fahmi el-battashy Feb 13, 2014
    RAM +HDD +CPU are good but still there is problem.
    Top Expert:
  • Computers & ... Master
  • 22,687 Answers
F it will go to BIOS screen, the motherboard would appear to be OK. What happens when you boot from your OS disc and select repair?
Posted on Feb 14, 2014
Testimonial: "...the problem is; it cant boot to the OS from HDD or even from CD while HDD and DVD-RW are clear/good"
  • 788 Answers
SOURCE: HP laptop display issue
If you are recving 1 long and two short beeps, it is not a memory problem.
It is not a Lid closing or lid switch problem.
If you are able to switch to and from your LCD and Monitor, you are lucky.
I have been up and down the road with several HP DV6000 series units, all have had the 1 long and 2 shot beeps.
HP is aware of this problem and has offered an extended 1 year from date of original warranty expiration. Another words 2 years from date of purchase. HP will ask for $365.00 + or - ? for this repair.
Their repair consists of a motherboard replacement.
If you go to HP's web site, you can look up your model and if in warranty, have it sent back for repair.
The problem will not get better in time but only worsen. The heat sink on the dual core units is not handling the heat transfer properly.
The board is a 2 sided wafer which has displayed failure in several places, due to the heat load and transfer design. Area of problem is directly under NVIDIA chip look for craters. Theses are solder points the size of a pins head which because of the heat and the stress of the transfer bracket above, have separated making in some cases an intermittent connection to chip.
The best thing to do is have a technician remove the board from inspection and blow out the heat sink and surrounding areas.
Apply new heat sink tape and grease where needed and re-assemble.
You must update your BIOS ver. to current.
This new version will address the Voltage and Fan Control Speeds in a better manor.
If your unit is just now giving you these errors, now is the time to act.
Just like in a A/C unit at home, a restricted air flow will make unit run longer and hotter.
Their are no filters here, once lint and dust have collected in the coils, it is just a matter of time.
Hope this helps you in your problems.
Anybody reading this note having a DV6000 series unit, should check at their web site for warranty and call back issues.
John
john@johnrraycomputer.com
P.S. if you are a technician and feel you want to repair the board yourself, drop me an email with the model number and I will explain in more detail.
Posted on Jun 11, 2009
  • 58 Answers
SOURCE: "A disk read error has occurred. Press Ctrl+Alt+Del to restart."
try this. load defaults on bios. retry boot from xp cd. on windows setup. choose recovery console. on dos mode. choose OS (XP). Run CHKDSK /R.
Posted on Feb 16, 2008
  • 928 Answers
SOURCE: HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Posted on Sep 05, 2009
nicoleFIXIT
  • 154 Answers
SOURCE: HP Pavilion dv6636nr boot problem
When we talk about laptop won't boot up it is a hardware failure.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
Good luck and take time to do a hard troubleshooting this trouble is not easy as well. You need to be care full in removing the some parts so that the other will not affected and being damaged.
Posted on Dec 02, 2009
Testimonial: "thanks! i was not waiting long enough before replacing the cmos battery back in its slot. after a ten minute wait, it did the trick. you rock."
SOURCE: My laptop Preasario cq61 has the black screen
http://h10032.www1.hp.com/ctg/Manual/c01141784.pdf
OK download that service manual, follow the troubleshooting procedures and you will sort your problem out in now time, i have a hunch, that your HDD, is faulty... and may need replacement. Anyway Download and use that manual, it's a generic one.. but will still work for you.
Posted on Apr 11, 2010
Want to upgrade RAM for my Laptop, Lenovo G50-80. Can any one please suggest any Lenovo authorised Laptop service center in Dubai?
I am not aware of any in Dubai. You can upgrade up to 16Gb.
See link for details. It is not complicated to replace the RAM.
http://www.mrmemory.co.uk/memory-ram-upgrades/lenovo/laptop/g50-80?search=lenovo+g50
Aug 10, 2015 | Lenovo Computers & Internet
Asus g50 has no boot mgr, and when i try to reload windows it wont recognize any hdd?
Try booting in safe mode first.
Start your PC and as soon as it starts, keep pressing the F8 key continuously. If a screen comes up with an option to start in safe mode, go to that option. If you can boot to that option, go to start-type in system and look for system restore. Click on that and follow the instructions.
If you can't do that then look here:
http://www.tomshardware.co.uk/faq/id-1945283/tutorial-fix-bootmgr-missing-error.html
Dec 10, 2014 | ASUS Computers & Internet
I have a hp 89810-001 laptop motherboard.
ok check to see if hard is good first with another computer first than try a new video card if drive is bad make sure that all power cables are right at the same time check to make sure that you have the right ram as well ok let me know ok jim
May 15, 2014 | Gateway HP 489810-001 G50 AMD CPU...
Took out the battery in my HP G50 126 NR now the nothing happens and the power button just blinks
how many times does it blink its usually a code once for cpu failure 3 for hdd stuff like that or it just could be power adapter problem hope this helps get back to me and I will try to back to ya asap
Jan 16, 2014 | Computers & Internet
Asus g50 vt-x5 will not POST or boot
Have you tried connecting it with another display?
Jan 06, 2013 | ASUS G50V-A2 15.4IN Notebook
HP G50-111NR went dead while booting up. Now it will not turn on. Lighting bolt blinks three times when power botton pushed.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 31, 2011 | HP Pavillion G50-111NR Notebook
I have an HP G50.The HP screen comes up and then the computer freezes.It will not boot up any further. HELP (it will not let me hit the esc key for the startup menu)
http://h10032.www1.hp.com/ctg/Manual/c01572022.pdf
Above is a service and repair manual, perform the troubleshooting steps within and sort your problem out.
The best way is swap out parts, RAM, HDD, DVD, etc, for KNOWN good ones, and reboot and see if it works. If you have your recovery DVD, pop that in your drive and try to preform a "Start-up Repair".
Or try F8, at bootup, and select SAFE MODE, when at safe mode decision screen, choose restore system to anther time, and choose a time before your PC failed.
May 21, 2010 | Computers & Internet
Warranty?
contact hp support on line
Apr 10, 2010 | HP Pavillion G50-111NR Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
