Question about Allegro DVD Recorder VCR Combo ABR521
Manual allegro abr521 - Allegro DVD Recorder VCR Combo ABR521
Allegro vcr algc401 need a manual
Try Googling (allegro)(algc401)(manual) without parens.
May 05, 2017 | Allegro Televison & Video
I want to change the dialing number on my allegro GE security system, part no. 60-874-95R. Can you help with this without the vendor's help? Thanks
Follow the instruction on the install manual, page 7. you should start by cleaning the memory of all the previous data - as explained in page 6.
If you don't have the manual get it from here
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ALLEGRO_Install.pdf
Sep 07, 2011 | Allegro Ge Iti Allegro 80-795 / 60-879-95r...
Dvd does not play video just music
Check your video connection (assumi8ng you nhave the LELLOW / RED & WHITE cables) or if using a RF (cable) connection be sure you are on the right channel (3 or 4). Worth a shot. Beyond that, you have other issues.
Dec 29, 2010 | Allegro DVD Recorder VCR Combo ABR521
Some buttons don't work on the remote, some do???
The remote control might need to be repaired. They repair them at http://www.replacementremotes.com/ and they sell self repair kits at www.keypadrepair.com
There are other sites but I use those because the company I used to work for relied on them as a reputable company and I don't know about the others.
You can try a remote reset by turning off and unplugging the Allegro. Leaving it unplugged take the batteries out of its remote. Point the remote at the Allegro as if you were going to power it on. Hold down the power button for two minutes. Then press and release each button on the remote control twice. Next plug the Allegro back in and power it on from the on off button located directly on it. Then put the batteries back in the remote control and try it.
Sep 28, 2010 | Allegro DVD Recorder VCR Combo ABR521
At&t 200b remote controller for a mitsubishi tv
I have the instruction sheet for this remote. I scanned and posted it on my site
http://roburt.com/ATT-200B.html
good luck! Robert
Feb 05, 2009 | Allegro DVD Recorder VCR Combo ABR521
Brand new dvd but the drawer won't open
input output plugs were not in the right slots
Jan 24, 2009 | Allegro DVD Recorder VCR Combo ABR521
I need program for remote control-AT&T 200b
Sharp 026 • 091 • 129 • 141
the guide can be retrieved from
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/us_electronics_uf4200c_manual.pdf
On the remote control, press and hold the appropriate mode key (TV button) until the four mode
keys flash twice. The mode key will continue to flash.
Enter the three-digit code. See above I gave all the Sharp codes.
After you press the first digit, the mode key should light and stay on. After you press
the last digit, the mode key should flash three times and turn off.
If the mode key does not flash three times before turning off, the code is invalid for
this device type. Repeat the procedure with another device code.
Point the remote at the device and press POWER. If the device turns on or off, you
have finished programming.
If you have tried all the codes listed for the manufacturer and the device does not
respond, refer to the CodeScan™ section later in this manual.
Jan 07, 2009 | Allegro DVD Recorder VCR Combo ABR521
Model abv441 Picture flutters when playing vcr tape
Remove the casing of the unit. You will see a head where the tape runs across. Keeping it powered up, with tape in....There are three screws around the base of the head. With a small phillips adjust the head by turning the screws one by one. If you adjust out too far, the screws will come out completely. Take your time when adjusting. You will notice the picture change with the turning of the screws. The sound will change also. It takes very little adjusting to get it right. Play around with it and it will work in no time...Good Luck
Dec 16, 2008 | Allegro DVD Recorder VCR Combo ABR521
Televison & Video Logo
109 people viewed this question
Top Allegro Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Repairing
Computer Repairing
ray gallant
Are you an Allegro Televison and Video Expert? Answer questions, earn points and help others
