Question about Bosch Vision 300 Series DLX WFVC4400UC 27" Front-Load Washer - White
Bosch washer program codes - Rinse only??
I have a Bosch Vision 300. There is no "rinse only" button for this model, but I think there is a program code for it. I can get to the codes, but don't know which one to select for rinse. My choices are P:01-P:14
  • 27 Answers
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Posted on Jun 26, 2007
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
  • 9 Answers
SOURCE: Bosch classixx 1400 express wont spin or rinse.
why life so unfair ?
Posted on Jan 27, 2011
How to clear error code e27 on bosch vision 300 washer
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
5. I set the knob back to off, and the washer now appears to be operating.
6. You're done.
Feb 08, 2016 | Bosch Vision 300 Series 3.3 cu. ft....
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
My husband interrupted the spin cycle on our Bosch front load washer and now we are getting an E27 error message. What can I do to fix this?
Here is what worked...
6. You're done.
Aug 29, 2015 | Bosch Washing Machines
Why does my Bosch Classixx 1200 Washing Machine rinse if I turn switch to rinse but will not rinse when automatically.
Are you on a delicates program that has no spin or is there a no spin button that has been pressed?
Check the manual to see what programs do what. You can usually find a manual on line if you have lost yours.
Dec 13, 2014 | Bosch Washing Machines
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
I have a Bosch dishwasher with a rinse indicator light. When the light is on it's supposed to be indicating that the rinse aid is emptybut my rinse aid container is not empty even though the light is on....
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
Jun 25, 2010 | Dishwashers
Cloths are cold after final rinse cycle ...they use to be hot
The clothes should be cold after rinses, if they were hot before, then something was wrong.
Most washers do at least 3 cold water rinses, so they should be cold, this prevents creasing.
Hope this helps.
Jan 18, 2010 | Bosch Nexxt 300 Series WFMC2201UC
I don't know where to put the Rinse Aid
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
May 22, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Bosch Vision 300 Series DLX WFVC4400UC 27" Front-Load Washer - White Logo
27 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
