Question about Transmission & Drivetrain for Ford Transit Connect
2011 ford fiesta clutch
Clutch is wanting to pull when depressed. but drove fine when parked night before.
  • Ford Master
  • 694 Answers
Maybe check the slave cylinder make sure there is no air in the system
Posted on Mar 02, 2014
I want to know whether it uses both gear oil and ATF
There is NO dipstick in these transmissions and are considered "maintenance-free". Is it leaking something?
Transmission Fluid Level Check Ford Fiesta 2011 2014 2011 Ford Fiesta SE 1...
Oct 20, 2015 | 2013 Ford Fiesta
Ford fiesta clutch
Sounds like the clutch is adjusted so it touches a little... not good.
The sound could also be from a burned out Throw-out Bearing. From the CarTalk web site:
"TOM:
The second most common type of clutch failure is when the throw-out bearing (also called the release bearing) fails. That\'s the bearing that pushes the clutch plates apart when you push in the clutch pedal to change gears."
It makes a roaring sound when you push in the clutch pedal. Silent otherwise. Its a pain to replace, as you have to get the engine and transmission separated. Sometimes you have to pull the engine, sometimes the transmission, sometimes both!
That is why that work on the master cylinder and slave cylinder are so critical, and why proper adjustment is vital.
They will probably charge a lot, but its a lot of work. If they pull the engine or transmission, may as well get a new clutch and certainly a pilot bearing, too.
Then again, you may be lucky and its just a clearance adjustment in the clutch slave cylinder.
Dec 17, 2013 | Cars & Trucks
Gas nozzle continues to shut off when filling the gas tank.
The problem is the NVLD module. Its a known problem with Fords. Once it is replaced, the problem immediately goes away.
Aug 30, 2013 | 2011 Ford Fiesta
1999 1.4 Ford Fiesta: When depressing clutch a very noisy rumbling sound but gear changing as normal. I added some gearbox oil and the noise stopped. Then, just the following day, no resistance when...
Hi There.
sounds like your release bearing has either collapsed or seized, either way you will have to drop the gear box and check it out... should'nt be a problem on a 1999 fiesta. just be careful not to pop a drive shaft and lose the transmission fluic on the floor.
Good Luck
May 03, 2011 | 2007 Ford F
I have an 02 Ford Fiesta. Rattling soun when clutch is depressed.
Unfortunately, you can't really tell until you have the parts in front of you. If the clutch showed no signs of slipping in any gear, then the disk and pressure plate are probably ok. Throwout bearing troubles are usually heard as a sort of screech when the pedal is depressed. If the pressure plate is the type that has 3 fingers that are pushed by the bearing and one of the fingers was bent/broken, it would make a rattling sound. If the car has considerable miles, it might be worthwhile to replace the whole assembly even though the clutch itself seems to working well. Hope this helps!
Mar 19, 2010 | Ford Festiva Cars & Trucks
Ford Fiesta 1.25 Zetec - Gears not engaging so no drive power
Sounds like your clutch cable is caught. Try new cable.
May 19, 2009 | 2000 Ford Escort
Ford fiesta 1.3 97 petrol sometimes won't start
change battery ,if it starts with jump leads battery flat or altenator not charging
Nov 17, 2008 | 1998 Ford Escort
Transmission & Drivetrain for Ford Transit Connect Logo
47 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
