Question about Tanita Health & Beauty
Tanita 1623 batteries don't install when replacing.
Our tanita HD351 scale not working
It is possible the replacement batteries are defective, the wrong type, or not installed correctly.
Jul 14, 2016 | Tanita HD 351 High Capacity Bathroom Scale
How to clear memory from a HD 351 Tanita Scale?
leave battery out for a while or look for a pin hole to put a pin in to reset it
Jul 06, 2015 | Tanita Health & Beauty
On my Tanita BC-534, I just changed the batteries but now continually get "Lo" in the display. So tested batteries and even tried other batteries, but still get the same message. Please let me...
Hi BJ,
Welcome to fixya!
According to the manual, "Lo" indicates weak batteries. Since you changed batteries, my next question would be... Did you buy fresh batteries at the store or use ones you had at the house? Check the freshness date on the battery package. Sometimes even some of the ones you get in stores aren't fresh enough.
Since you get enough power to get "Lo" reading, but not enough for anything else, this sounds like a battery problem.
Did you check the contacts in the battery compartment? Sometimes cleaning them with a pencil eraser will help make better contact. Also, be sure the springs are tight enough. If they are the tab kind, you can bend them out a little for a tighter fit.
If all else fails, here is the contact page for Tanita: http://www.tanita.com/en/contact-customer-service/
They should stand behind their products.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 26, 2011 | Tanita BC-534 InnerScan Body Comp Scale
Hello, my new device Tanita BC 532 measure weight and body fat%, but no reaction when I try to press rest of the featured keys. I use the description attached, and the weigth and fat% showes alternly on...
My Tanita BC-532 also developed this fault. It seems to be common with a number of the models! I asked Tanita and over a number of emails this is what they said:
"not to place it in wet rooms and remove the batteries if stored for a longer time period."
When I said it was in a bathroom (isn't that where everyone keeps their scales) NOT a wet room - they said any bathroom is classed as a wetroom!
When I said how can you tell if the batteries are just about to run out (that's what seems to trigger the fault) I had no reply; and when I asked how long is a "long period of time" - 2 weeks/ 2 months (we used to use ours every 1-2 weeks) again no reply to this question.
Now out of warranty after 5 years Tanita suggested it I didn't follow either of these instructions above (in the manual, but not defined) then I only have myself to blame. They did suggest one remedy was to:
"1.Take out the batteries.
2.Make a short-circuit between (+) and (-)with a piece of wire.
3.Put the batteries back and try it out.
If that doesn't work, you simply have to discard it. "
Personally I don't think this is satisfactory and I won't buy Tanita again. Scales should last much longer. They should make any warnings clearly defined - especially based on the number of times this happens according to reports from users on internet.
It seems this is a well known fault and I would thus suggest scales are not fit for purpose over longer term. Tanita should own up to this and stop avoiding their responsibilities.
Should you not keep in the bathroom, use every few days, and replace batteries before they get too low - then these scales are great (well they were for the first 5 years!)
Dec 25, 2010 | Tanita BC-533 InnerScan Body Comp Scale
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Tanita innerscan stopped working. New batteries installed but will not switch on. There is no display except on the guest button which comes up with "88888" when pressed. Any ideas - thanks
Maria,
sorry no, i don't have a sltn. however i recently experienced the same issue w/ my tanita innerscan. i've just notified Tanita's customer service... have you had any progress?
Dec 30, 2009 | Tanita BC-533 InnerScan Body Comp Scale
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Tanita BC-552 Body Composition Monitor Won't Turn On
I contacted Tanita for you and am working on the manual the link here is for the download however the file says it is currupt maybe it will work for you. if not I have requested it from tanita. http://www.tanita.com/en/downloads/personal/
This is the response from Tanita
Thank you for your e-mail.
It appears that this could be a battery connectivity issue.
When you change the batteries – please insure that you are getting a nice tight fit and that the positive side of the batteries are making contact with the inside wire. Sometimes the batteries can differ in length so you can gently pull on the coil to help make it fit more tightly. Also take a look at the inside contact points to make sure there is no rust. If there is rust – you can clean by using a green kitchen scotch-brite pad & a q-tip dipped in rubbing alcohol.
If you continue to have problems we may be able to replace under warranty.
Your scale does carry a 10 year warranty but you will need to have a copy of the original itemized receipt (or order confirmation if purchased online) in order for us to process a warranty claim.
If you happen to have a copy of the original receipt or order confirmation, please contact our customer service line between 8:30 – 5:30, Monday – Friday, (Central Time) at 847-640-9241, and we can issue you a Return Merchandise Authorization for product replacement
Sincerely,
Cheryl Morse
get-attachment.aspx?uid=1.23025525&folder=oldmail&partid=4
TANITA CORPORATION
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005
Office: 847 434 3985
Email: cmorse@tanita.com
Apr 26, 2009 | Health & Beauty
Health & Beauty Logo
62 people viewed this question
Top Tanita Health & Beauty Experts
dkmun
Level 1 Expert
Ankit Chandel
Ankit Chandel
Terry
Terry
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
