Question about Viking Pro-Style 30 " Freestanding Stainless Steel Gas Range - VGSC5304BSS
Viking Pro-Style 30 " Freestanding Stainless Steel Gas Range - VGSC5304BSS not keeping temperature in oven
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Posted on Jun 02, 2008
SOURCE: viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Posted on Dec 10, 2008
SOURCE: Oven will not maintain temprature
This is a parts problem, I think called the burner ignitor. It is a pn oven part. We have had it in the past and are experiencing it again. We have had our stove for about 15 years, so I guess it is not too bad a problem, but not inexpensive. The oven is letting the gas be off too long between reignitions, so it does not maintain temperature. The first time we realized the probelem was with the Thanksgiving turkey (pink in the joints.)
We had to have the part replaced about 7 years ago and the part was about a $200 part plus service call. I am sure it more costly now. Hopefully you can get yours under warranty.
Posted on Dec 14, 2008
  • 42 Answers
SOURCE: my viking electric oven does not have accurate temperature
how bad is the temp off?
Posted on Dec 21, 2008
  • 23 Answers
SOURCE: Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Posted on Sep 18, 2009
All 5 spark igniters not clicking
Could be range of problems including:
Power not connected/turned off
Ignitor ports clogged
Incorrect operation
Manual is available via Google
Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
Is there a fuse on the Viking Pro freestanding gas model? Can't find anything in the manuel. Thanks
Hm, there is a hi limit switch between the range top and oven cavity. Ck your door to see if its sealing . If heat is escaping have a servicer look at your hinge receivers so the door will seal.
Mar 12, 2014 | Viking 30 " Pro-Style Stainless Steel...
Oven temperature is off by 25 degrees
Unplug the power and wait 15 minutes. Plug it in and retest to see if temp comes back to normal. + or - 5 degrees is normal. If still same problem than you will need to re[lace the controller board.
Dec 22, 2013 | Electrolux Icon E30df74gps 30" Pro-style...
Our GE Gas range oven model JGB918SEKSS is having a problem in the oven where the ingiter lights but the oven does not heat up. There is no gas going into the gas pipe and so it does not ignite. Do I...
Replacing the ignitor MAY help but the oven gas valve needs attention and adjusting...not a job for amateurs, leave it to a professional, it is GAS we are talking about.
Sep 26, 2017 | GE Profile 30" Self-Cleaning Freestanding...
Cleaned the range, now all four pilots are continuously sparking it will lite when gas is turned on, but continues to spark
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Feb 17, 2011 | Maytag Gemini 30" Self-Cleaning...
The burner igniters continuously click.
Gas Range Repair Burners Keep on Clicking
heatman101
Oct 05, 2010 | Maytag Gemini 30" Self-Cleaning...
What does F2 mean
F2 means that the oven temperature has exceeded 590 degrees with the door in the unlocked position. There is high resistance or interference in the oven termperature sensor. Replace the oven temperature sensor.
Nov 18, 2009 | GE 30" Self-Cleaning Freestanding Electric...
. THE MESSAGE APPEARED WHILE I WAS CLEANING THE
F1:-4 Runaway Clean Lower oven Check oven temperature sensor, replace if necessary
Nov 09, 2009 | Maytag Gemini 30" Self-Cleaning...
F2 is flashing and alarm is going off!
This is what the code means.
F2 For an unknown reason, the oven temperature has exceeded a preset threshold.
press the clear button for 10 sec. to try to stop it.
Good Luck and Please rate Fixya!
Dec 29, 2008 | GE Profile 30" Self-Cleaning Freestanding...
Viking Pro-Style 30 " Freestanding Stainless Steel Gas Range - VGSC5304BSS Logo
14 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
