Question about Magnavox SDT Tuner
Magnavox sdtv tuner stopped working. Powers on, light slowly blinks green like normal, then blinks faster, and goes back to standby.
It worked fine for a few years. We just had a bad storm. The power went out several times overnight - a few seconds at a time. In the morning, it didn't work anymore. Tried turning it on, but it would just blink and go back to standby. Tried powering off for an hour or two, unplugging/re-plugging - standard trouble shooting - still doesn't work.
SOURCE: 3 month old magnavox mdr515h/f7 is dead. It may be
My unit was dead also.....So I checked outlet first...It was good....Then I tried the 10 minute disconnect and reconnected unit......Saw Unit had power on LCD screen....Hit ON button on remote after changing to HDD and unit works perfectly again....That fix saved me 75 bucks for repair center to do same thing...Glad Funai makes units that shut off before damage occurs...Unit just needed to cool down hard drive or circuitry before it sensed it was ok again....When plugged in it is still technically powered even tho you dont see it on the LCD screen of the unit...
Posted on Nov 04, 2011
wendyschaffe
SOURCE: MAGNAVOX 37MD359B /F7 TV turns
magnavox 37mf23id/33id/32id lcd no power
Posted on Jan 02, 2012
atang1
  • 734 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Posted on Feb 21, 2012
SD Tech
  • 14553 Answers
SOURCE: magnavox 42mf439b no picture power light blinking.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_9_15_06_pm.jpg
look inside at power board to see if puffed up (bad) caps like these.
Posted on Apr 10, 2012
Terry Corrow
  • 10875 Answers
SOURCE: How do I program my TV Tech Monster Remote to my Magnavox SDTV tuner?
0186, 0171, 0030, 0024 Or try universal code 0000
Posted on Apr 19, 2015
I have a sharp GA292SB TV and am trying to program a magnavox sdtv tuner to in but do not have the remote for the box. Want to program to tv remote
If your Sharp remote is capable of being used with other devices such as your Magnavox STB, you should be able to get it to work.
May 21, 2016 | Televison & Video
Tv will not power up
Did you try leaving the TV disconnected overnight?
Apr 01, 2008 | Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Why wont my car start in the mornings?
Sounds like you are loosing fuel pressure overnight. Could be a fuel pump problem, or a leaking injector.
Aug 03, 2014 | 2003 Pontiac Grand Am
Lights only go on standby
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Toymax Magnavox 37MF231D 37 in. LCD TV
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Need owners manual for Magnavox SDTV tuner SDTV tuner E175216
bluebonnet_1
I have provided a link where you can look for a manual or ask where to obtain a manual from a Magnavox tech. I hope this helps.
http://tv.manualsonline.com/manuals/mfg/magnavox/magnavox_crt_television_product_list.html
Ray Calo
DISH Network
Feb 27, 2011 | Televison & Video
My acer al1914 wont power on... was working fine,
The usual suspects, blown fuse, blown capacitors, bad solder joints. Any of this conditions could be your problem.
Jul 16, 2010 | Acer AL1914 19" LCD Monitor
Magnavox SDT Tuner Logo
102 people viewed this question
Top Magnavox Audio Players & Recorders Experts
Jay Plesset
Are you a Magnavox Audio Player and Recorder Expert? Answer questions, earn points and help others
