Question about Weslo PURSUIT CT 4.2 Recumbent Cycle
How do i stop the scraping metal sound when i pedal my bike
When start pedaling it makes a beeping noise that will not stop
Sorry, but more information is needed;
What do you mean a "Beeping" sound ?
Beeping is usually associated with electronics.
Do you mean like something is rubbing, perhaps a brake shoe along the rim, or a metal on metal sound ?
I am assuming the sound stops when you stop pedaling or stop the bike's motion - one or the other - which is it ?
Oct 04, 2015 | Cycling
Car runs nicely on highways. When I am in stop and start traffic for some time and I press the gass to move off. I get a flat spot (absolutely no response)the car does cut off. After a minute or so I mash...
any error codes? sounds like a fuel delivery problem when you need it. I'd guess a bad connection at the throttle position indicator. Scrape to bright metal reconnect. Get codes read at an Autoparts store, that may help diagnose. Could be fuel pump or more likely a fuel pump relay, but they should produce error codes.
Mar 18, 2015 | Cars & Trucks
While I am driving when I am pressing the gas pedal it makes a scraping noise but not all the time. If I hit the brakes it will stop. I have a 2001 Nissan Sentra GXE
Sounds like it might be the low brake pad indicator. A small flap of metal which is made to scrape the rotor when the brake pads reach a certain low level. When brackes are applied the noise typically quiets.
Check for worn front brake pads.
Jun 26, 2011 | 2001 Nissan Sentra
When the bike is peddled there is a clicking sound. Is this normal? The bike hasn't been used for about a year.
I think the clicking noise is caused by one of two common issues. The easiest is that the little black computer pickup is too close to the magnet located on the right plastic piece on the right side of the wheel and everytime the wheel makes a full circuit while peddling, that little black piece clicks as it actually hits the magnet. If that's the case, then pull the black magnet sensor away just 1/16 of an inch aways so it will not hit the magnet everytime it passes the magnet. You can tell what's causing the clicking noise by getting on the floor and pushing the pedal around with one hand slowly and looking closely at the tow places I will mention to determine where the clicking noise comes from and then making the adjustment to stop it. the other place the clicking can come from is the chain rubbing against the metal on the left side. It might be hitting the TOP of the metal cage when cycling OR the BOTTOM of the metal shield which covers the pedal assembly. Look closely at the left side of the bike while peddling the bike slowly to see if the noise is metal against metal. You can shift the cage slightly to take the pressure of the cage from scrapping the chain by sitting down in front of the bike facing the cage and placing both feet onto the left & right supports (they're what hold the bike up) and you grab the little black wheels on both sides with your hands and push down slightly but firmly to shift the cage a bit and it will move up or down depending on where the chain is scrapping it when you cycle. That cage will shift slightly over time and it can make a loud noise when it scrapes the chain. I hope this helps. If not, give me a reply with more details and I'd be glad to help you isolate and fix the problem. Leave postive comment on fixya if you like my solution. Luke terpcafe@yahoo.com
Jan 16, 2011 | Schwinn Original Airdyne
Scraping/Squeaking noise on recumbent stationary bicycle
There are most likely some sort of bearings inside the wheel hub that are causing this.
Jan 13, 2010 | Cycling
In a 1998 4x4 jimmy 4 door I am experiencing a vibration which feels like its in the front end. the only occurs while accelerating, but stops almost instantly after letting off the gas pedal. Vibration...
This could be a loose hub bearing causing the hub to move in and out .When accelerating the weight shift will be less on the front wheels so the hub may be moving in and out during this .Have this checked soon :)
Nov 05, 2009 | 1998 GMC Jimmy
Ford 1988 escort GL-Front wheel constant scrape-scrape,vibration
sounds like you need new brake pads and the rotors atleast turned down if not replaced
the pads should stop the noise and the rotors should stop the vibration/wobble
thanks wes
ps please rate me
Mar 27, 2009 | 1988 Ford Escort EXP
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Weslo PURSUIT CT 4.2 Recumbent Cycle Logo
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
