Question about Refrigerators
Water won't dispence from the water dispencer on my GE side by side model #HSS25GFPJWW. The water comes out of the line that is hooked to the line in the freezer
  • Refrigerators Master
  • 4,655 Answers
The ice maker uses one half of the=> WR57X10040 Water Inlet Valve so it is still possible that the WR57X10040 Water Inlet Valve
is still defective, Thanks John Tripp Appliance 911
Posted on Feb 14, 2014
SOURCE: Clicking noise on GE GSH25SGRE SS
The main controlller board is bad and must be replaced.
Posted on Jan 10, 2008
22yooper
  • 828 Answers
SOURCE: Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Posted on Jul 05, 2008
ngafm
  • 166 Answers
SOURCE: GE side by side water dispencer area Leaking
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
* You can also schedule service by calling our toll free number:
800-374-4432 M-F 9:00am - 5:30pm.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
Back
3. Noises / Sounds.
* Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Posted on Sep 05, 2008
  • 958 Answers
SOURCE: sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
tech master
  • 120 Answers
SOURCE: Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Posted on Nov 18, 2008
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Can not get water from the dispencer, checked all the inlet valves and they are working. disconnected the water hose going to the dispencer and water will flow when the switch is activated at the door....
If I read you question right, you can disconnect the line at the bottom of the door and water will come out when you push the button but when you reconnect the line it will not come out of the dispenser. Right?
Simple answer... It is frozen in your door.
What I need to know is your serial#. I think it is the forth digit will be a 2 or a 4. If it is a 2, then there is a kit to keep it from freezing part# WR49X10173. When you look inside your freezer, you will have a steel liner( check with a magnet if not sure).
This kit will not work if it is a 4.. Do not try,it will not fit!
If it is a 4, then the only solution is to replace the door which is probably no longer available since ge is now owned by Haier :(
If it is a 4, you can defrost the door and see if it comes back. (unplugged,doors open for up to 24 hours but it will probably work within 6 hours or less) After defrosting, bump your freezer temp up a couple degrees and see if it comes back.
Feb 01, 2018 | GE GSS22JF Side by Side Refrigerator
Water dispenser does not work
The lines are likely clogged and will need to be removed and cleaned. Otherwise, although the pump starts, the valve may be clogged or non-functional.
Feb 11, 2018 | KitchenAid KSSS36QK Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Water dispencer want work
yes the filter will keep water from dispensing but the best way to see if it is it is take your kickplate off under your doors and you will see a water line coupling unhook it there by putting your fingers on each side the line and pulling back on the coupler then put the line in a glass or bowl and push in on your dispensor paddle if you have water there then call a authorized technician cause it is frozen inside the door
Dec 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water won,t dispence from the freezer door. the water pumps to the bottom of freezer door,but don,t come out of the nozzel.
Water line in door is frozen. Set frzr warmer and leave door open an hour or so so it thaws out.
Nov 27, 2008 | GE Refrigerators
Water dispencer
Greetings,
Remove the water dispenser assembly and check the pipes
Jun 23, 2008 | GE Profile¿ Arctica® Energy...
Whirlpool side by side water dispencer
Sounds like some switch wires at the water valve.
Should be color coded.
May 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice M. Works but Water does not
water inlet is stopped up ,or has gone bad. the valve is located behind the box ,where the water supply line is hooked up
Feb 27, 2008 | GE GSS25IFPCC / GSS25IFPWW Side by Side...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
