Question about Kenmore Dryers
I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. I was told to make sure the two wires connected to the metal strips in the lent box were securely connected - they were, and the dryer still does not work. the check lint screen is still red.
  • 67 Answers
SOURCE: Replacing a defective Terminal Block - Kenmore Dryer
If there are any lose wires connected to the dryer terminal block and there is any sign of current draw like black around it or if it just looks bad in general then yes it does pose a threat of a fire hazard or electrical hazard like shocking you when u touch the frame. There is a terminal block you can buy for it visit any part place with the model number and they can help you out hope this helps
Posted on Mar 21, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Posted on Oct 29, 2008
Jahn27
  • 1554 Answers
SOURCE: Model 11-85862400: Check Lint Screen light
Disconnect power and remove the two screws from the bottom flange of the toe panel then pull the panel down and off the cabinet.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct.
Remove the wires from the terminals of the thermal fuse then join them together and insulate the connection properly.
Reconnect power then press start. Replace the thermal fuse along with the thermistor if the dryer starts. The thermal fuse is wired in series with the motor and if it is blown, power to the motor is terminated and will not run. No dryer function works when the motor doesn't run. The thermal fuse usually blows due to failed thermistor or blocked lint screen or vents. This is the reason the "Check lint screen." message flashes.
Disconnect power, if the dryer still doesn't start, then remove the top panel and check if the belt is still on. The belt activates the belt switch which is also wired in series with the motor and the thermal fuse. The motor will therefore not run if the drive belt is off and the belt switch is not activated.
Check the wire connections on the electronic control board. The electronic control board has indeed failed and needs to be replaced as what the Sears repairman said. The electronic control board is part number 8546219 and it costs about $180.
Posted on Feb 12, 2011
  • 183 Answers
SOURCE: I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. The lig
when you removed the screen from the inside you disconnected the wires from the 2 metal strips. now you need to remove the lower panel on the front. and reconnect them. you will need a T-20 torx and unplug the dryer to be safe. the wire will have 90 degree push on connectors and it does not have any polarity concerns. the two male connectors are real close to the top of the panel, maybe even slightly under the other panel. By the upper right of the silver fan duct.
Posted on Jan 03, 2012
bcyrsgallant
  • 11 Answers
When you cleaned the lint out and of course you removed some plastic pieces that went around the screen area. I with you up to there. Did you notice the plastic clip with a metal clip like thing on it. I'm not going to try walk you through every detail. But when I first read your post. I thought about the clip that holds the door closed some of the newer units use a ground to sense if door is completely closed and if accidentally knock the little metal part off which is fairly easy to do. The unit won't receive the ground for its confirmation of the door closed. And yes it may be trying to find it's door lock and that maybe the clicking or knocking sound
Posted on Jun 19, 2014
Kenmore washer front load 3.5 super capacity clogged pump.
Remove the lower front panel and unscrew the LARGE 3" round plastic access cover. Have a drain pan handy as it will pour out water! Dump the coins, lint and whatever is collected in there, reinstall, tighten securely and replace the lower panel.
Jan 17, 2015 | Kenmore Washing Machines
How do i replace baffle w10113136 from my kenmore dryer
I would need the model number.
But there are a few ways. Basically you need to get the top off. Some models that don't have the consol on top you can just take the 2 screws off the back that go to the top and after the top is removed it is held in with 3 5/16ths screws.
Another model has the lint screen on the top. With that you take the 2 Phillips head screws under the lint screen off and use a putty knife where the front panel meets the lid and push them back to get to the drum. If the lint screen is inside the door on the front youtube how to take push the consol up and remove the 3 screws holding the lid down.
Basically you have to get the top off.
once the top is off you manually spin the dryer until the baffle you want to replace is on top. If it's fallen off you will also need the 3 mounting screws.
Dec 16, 2014 | Kenmore Dryers
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
Jan 02, 2012 | Kenmore Dryers
Hi, the tabs holding the white plastic handle on my Kenmore dryer lint screen broke. It has part number 348846 WHT on it. Can I buy a replacement handle or do I need the handle and screen assembly? Do...
Need model number of dryer. open door, should be located there.
Thanks and Please Rate Me!
TIPS Provided by: www.HoustonRefrigeratorRepair.com
Brian Gillespie, President & CEO
GOFAR Services, LLC
Aug 26, 2011 | Dryers
Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Jan 31, 2010 | Whirlpool Dryers
Kenmore washing machine model 110 he3t code fo2
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl. rate me nice for the free help!
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer takes too long to dry a load
Have you checked the lint screen? pull the lint screen out and remove the lint then hold flat and pour water on it. Does the screen hold the water or does the water flow through? If it holds water, then you must actually clean the film that has coated the screening material. Use dish soap and scrub lightly then rinse clean. and check again.
Apr 02, 2009 | Kenmore 62872 Electric Dryer
I need the schematic for my dryer series 80. Model number 11062822101 A night light bulb accidentally fell in the vent hole, when I pulled out the lint screen to clean it off. My dryer opens in the front,...
lift your lint lid and remove the 2 screws you see then pry the top up at the edges with a wide flat screw driver. If you have a rear cover remove it then remove the 3 crews that hold your lint catcher assembly to the blower housing and you should find your bulb
Mar 11, 2009 | Kenmore Dryers
Dryers Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
