Question about Chevrolet 2007 Chevrolet Avalanche 1500 LTZ
2007 5.3 liter engine code
Just replaced throttle body, and pedal. The truck still fells like it has very little power-miss and is getting around 9 miles per gallon. This is the flex fuel model, had to do the replace lifter, head gasket, repaired lifter from mis-fire.
  • dfscrichmond
    dfscrichmond Feb 14, 2014
    I did read were there a grounds on the back of the heads is that right on the 5.3 liter.
  • 140 Answers
SOURCE: Isuzu Hombre 4.3 (Chevy S10) 1997 won't start
Definitely check for spark next. let me know what you find.
Posted on Dec 30, 2008
Brian032472
  • 150 Answers
SOURCE: engine light comes on. Code is PO305 #5 cyl mis fire.
po 305 is cylinder 5 misfire detected. I would check the plug wire for starters
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: stalling, 'reduced power' light, and OBD code P1125 Manufacturer control air metering...
These trucks have a drive by wire system,we seen a` lot with a broken ground wire on the rear of the drverside cyl head,this is hard to see just feel and give the wire a tug .If the wire is loose or broken the reduced engine power light will come on.
Posted on Feb 15, 2009
  • 32 Answers
SOURCE: Poor gas milage
change fuel filter. but if it does not work u might have some leaky injectors
Posted on Jun 09, 2009
  • 144 Answers
SOURCE: code p0121 TPS
THERE IS A TP SENSOR BUILT INTO THE THROTTLE ACTUATOR. THESE TRUCKS HAVE BEEN KNOWN FOR A FEW PROBLEMS IN THIS AREA. THROTTLE ACTUATOR IS NOT SERVICEABLE. THE THROTTLE BODY WILL NEED TO BE REPLACED IF IT IS PROVEN FAULTY. THE APP SENSORS ARE LOCATED IN THE GAS PEDAL MODULE. THESE SEND SIGNAL TO COMPUTER TO TELL IT WHERE YOUR FOOT IS, THEN COMPUTER SENDS COMMAND TO THROTTLE ACTUATOR TO OPEN OR CLOSE THROTTLE BASED ON THIS INPUT. THE SENSOR IN THE THROTTLE ACTUATOR DELIVERS A MESSAGE BACK TO THE COMPUTER TO TELL IT WHAT THE ACTUAL THROTTLE POSITION IS. IF THESE SIGNALS DONT MATCH(WHERE THROTTLE IS COMMANDED AND WHERE IT ACTUALLY IS)THE CHECK ENGINE LIGHT WILL ILLUMINATE AND THE VEHICLE COULD GO INTO A REDUCED POWER MODE. HOPE THIS HELPS YOU!
Posted on Sep 07, 2009
Is the throttle sensor located at the accelerator pedal in a 2012 Jeep Patriot, Latitude (with 2.4 liter engine & automatic transmission, front wheel drive)?
There is one at the pedal and one at the throttle body. The one at the pedal tells the computer what throttle you want, and the one on the throttle tells the computer where the throttle is. Usually, if there is a fault code for the pedal sensor it will say "sensor A" and a problem st the throttle body sensor will say "sensor B", but not always.
Feb 02, 2017 | Jeep Patriot Cars & Trucks
2007 Yukon XL - P01121 Throttle/Pedal Position Sensor A Circuit Range/Performance.
P1121 GMC - Throttle Position Sensor Circuit Intermittent High Voltage
This codes has nothing to do with APP - accelerator pedal position sensor . This has to do with the throttle body - TPS throttle position sensor . These have know problems ,the sensor an broken wire at throttle body , an when this happens the cruise control wont work . The throttle works by a DC motor controlled by the PCM - engine computer .
Dec 30, 2015 | Cars & Trucks
COULD THE GAS PEDAL CABLE CAUSE THIS CODED PO507 to be high
Extracted from Engine-Codes.com
Code P0507
Possible causes
- Dirty throttle body
- Electric throttle control actuator misadjusted or damaged
- Faulty Electric throttle control actuator
- Intake air leak
- Poor electrical connection to the Intake Air Control (IAC) valve
help.jpg What does this mean?
Tech notes
If there are no intake leaks, clean throttle body, adjust engine idle and erase engine code. If the code comes back you may have to replaced the Electric Throttle Control Actuator (Motor) to repair the problem.
There is a factory service bulletin for the following Chevrolet models:
2006-2008 Chevrolet Trail Blazer
2007-2008 Chevrolet Avalanche
2007-2008 Chevrolet Express
2007-2008 Chevrolet Silverado
2007-2008 Chevrolet Suburban
2007-2008 Chevrolet Tahoe
Chevrolet Factory Service Bulletin OBDII Code P0507
When is the code detected?
Thi P0507 code sets when the Powertrain Control Module (PCM) detects an engine speed outside of the Idle Air Control (IAC) valve range of control.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine hard to start
- Rough or erratic idle speed
P0507 Chevrolet Description
The Idle Air Control (IAC) valve is a Powertrain Control Module (PCM) controlled stepper motor located on the throttle body. The stepper motor drives a valve pintle which protrudes into a passage that bypasses the throttle plates. The PCM commands the IAC valve pintle to extend to decrease the idle speed. The bypass air flow is reduced and the idle speed decreases as the pintle approaches its seat. The PCM retracts the IAC valve pintle away from its seat to increase the idle speed. The retracting of the IAC valve pintle allows more air to bypass the throttle plates. One of the PCMs uses for the IAC system is to maintain a desired idle speed. This DTC sets when the PCM detects an engine speed outside of the IAC\'s range of control.
Read more: http://engine-codes.com/p0507_chevrolet.html#ixzz3ObdI2chF
Jan 11, 2015 | 2001 Chevrolet Blazer
I have a Chevrolet Silverado 2007 new body style saying that i have reduce engine power code p2138
The automotive trouble code P2138 throttle/pedal position sensor/switch D/E voltage correlation refers to a problem related to the throttle's ability to open and close properly. Replace (suggest) the sensor (black object) on the throttle body.
Oct 08, 2014 | Chevrolet Silverado 1500 Cars & Trucks
Stabilitrak service comes on and i lose power. could this be the body modularsensor or throttle body sensor.
If you have a cable throttle then not likely, if you look at your throttle body and it is electronic then it could be the throttle body position sensor or possibly the accelerator pedal sensor. Are the any DTC codes present on your truck (check engine lights) cause both of these issues have sensors the will most likely trigger a code light on the dash. If not light comes on I would have it scanned just to make sure it doesn't have any codes stored in memory
Jan 02, 2014 | 2007 Chevrolet Avalanche LTZ
Dear Sir, I have a 1997 Jeep Cherokee Sport, 6 cylinder 4.0 liter. I recently tried cleaning my throttle body with carb cleaner while the vehicle was running. After spraying a half can of cleaner in the...
do a compression check on the engine, and replace the bad sensor, i take the throttle body off to clean it and some sensors are touchy about cleaner, i fear maybe something got on the egr valve pintle
May 26, 2010 | 1997 Jeep Cherokee
2003 Saab 9-5 Aero- Idling problem
Sounds like car is in limp home mode which needs reseting ,which may indicate you need a new Di Rail, or throttle body. Is engine management light on all the time if so Needs reseting. Hope this helps.
Sep 29, 2008 | 1999 Saab 9-5
Chevrolet 2007 Chevrolet Avalanche 1500 LTZ Logo
13 people viewed this question
Top Chevrolet Heating & Cooling Experts
Ted Maxwell
Andrew Taylor
Andrew Taylor
xkikbxr
Are you a Chevrolet Heating and Cooling Expert? Answer questions, earn points and help others
