Question about Frigidaire Washing Machines
Drains water but wont spin
The washer drains ok but wont spin. the door lock light does come on
  • Frigidaire Master
  • 5,323 Answers
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Posted on Apr 01, 2015
  • 1462 Answers
SOURCE: Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Posted on Jun 22, 2007
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
SOURCE: hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Posted on Jul 02, 2008
SOURCE: Washer fills wont spin out or drain water
I had the same problem. After releasing the door and removing the wet clothes, I siphoned the water from the drum. Make sure that the water is turned off and the machine is unplugged, Then I opened the large black cap behind the round white cover on the surface. Be prepared to capture about half galon of water. This is the opening to the drain pump. In my case, there were some toys from my kids which had stuck in the turning part of the pump. I removed them and replaced the cap to the pump. Everything seemed to be OK after that.
I hope that this helps. Please be adivsed that I am not a repair person and proceed with caution and use common sense when dealing with electric appliances.
Good Luck
Posted on Nov 08, 2008
  • 1550 Answers
SOURCE: my washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Posted on Jan 31, 2009
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Nov 28, 2010 | Amana Washing Machines
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Washer will not spin or completely drain
you could have problem with door lock. or lid switch. this part senses if the door is close.
if it is not functioning, it would interpret it as an open door and will not spin.will not drain either.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Washing Machines
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
