Question about Sony Car Audio & Video
Unit comes on, but no sound - Sony Car Audio & Video
How come the unit comes on but no sound on all functions ?
What's the unit? Hard to help without knowing what you have.
Aug 26, 2014 | Audio Players & Recorders
Problem turning unit on
it may have an internal shout somewhere causing the speaker protection relays to kick out..
Jan 18, 2014 | Sony STR-DE935
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
HEARING A BUZZING SOUND COMING FROM UNIT WHEN THE UNIT STARTS. COULD THIS BE THE BEARINGS GOING OUT IN THE MOTOR
If throttling sound comes it may from bearings or non alignment of blower wheel. But in your unit I think, it's freon flowing.Some times it may happens from to non serviced unit for long time. Service your unit. Helpful?
Jan 04, 2011 | Heating & Cooling
When the unit is off, it suddenly comes on with
Did you install this unit yourself? Also is the remote wire (blue) connected properly?
To me if it's spitting out cds and such sounds like a faulty unit.
Sorry for your luck
Aug 12, 2009 | JBL BP1200.1 Car Audio Amplifier
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
Only one walkie talkie produces sound
Check for Squelch Codes you can see on the display channel number and sub chanel number this is the squelch code
Both displays must show the same icons
If both are the same, try with and audio accesorie, if works may be your speaker is broken.
Dec 23, 2008 | Bell BE1400FRS (14 Channels) 2-Way Radio
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
22 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
