Question about Neff U1721 Double circotherm Electric Oven
U15M42N0GB oven element, light and fan all stopped working
Our neff oven element, lights and fan all stopped at the same time. The top grill element is still working as is the cooling fan. Any ideas?
barkencoa
  • 3463 Answers
SOURCE: Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Posted on Nov 21, 2008
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
  • 4932 Answers
SOURCE: The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Posted on Sep 01, 2009
  • 133 Answers
SOURCE: The bottom (fan oven) of my Neff U1721 made soft
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Posted on Dec 15, 2009
barkencoa
  • 3463 Answers
SOURCE: Have had 4 Neff oven elements in 2 years.
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Posted on Feb 07, 2010
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Neff single oven won't heat up. Replaced the main element and grill heats but when switched to fan oven the fan and light comes on but no heat?
If the fan is working o/k, then the element is faulty, or it is not getting power to it, you need to test with a meter for a supply to it.
Sep 23, 2010 | Neff Ovens
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Aug 25, 2009 | Neff B1421 Electric Single Oven
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Hi.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
