Question about LG LFC25776ST 25 Cu.Ft French Door Refrigerator Factory RefurbishedFOR USA
Where is the ice- detecting sensor?
Ice maker not working and manual says to clean it.
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Ice maker is not working - sensor bar rolls up but
Sound like it is the dual water control only. Try filling ice maker with tap water and then let freeze. If after the ice in the ice maker dumps the cubes into the ice container and does not refill I would think the water control valve is at fault. I see your model had three different choices of water control valves and listed on this page=> Here and in right sidebar about 1/3rd down the page you will see three different water control valves. Here is your Service Manual=> LG LFX25960ST Stainless Steel French Door Refrigerator Try this test first because you mentioned no water in trays. Let me know what results you get and if you have more questions feel free to ask, Thanks, Sea Breeze
Posted on Feb 15, 2011
My portable ice maker is not making ice, when turned on it shows ice full, but there is no ice in it. Any advice?
it seems the sensor is jammed or malfunctioning, fooling the control section and keeping the machine from working.
I don't know the machine but the sensor detecting the full ice section is either mechanical or a thermistor (electronic). Locate the sensor and make sure it is in position to sense or simply messing with it may make it work again.
Igloo may have a troubleshooting section in their website.
Oct 04, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
The sensor in the freezer has come loose
It belongs under the Ice tray to the Ice maker. Without it the unit can not detect temperature of the ice tray to cycle or function as needed.
I hope this helps.
Mar 23, 2013 | Fisher Paykel E522BRXFDU Fisher & Paykel...
I need instructions on cleaning a Hoshizake ice maker
go to: http://www.hoshizakiamerica.com/. Click on "Support". fill in the model of your unit then click "get manual" and you are there.
Dec 06, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
Ice machine keeps going to "off" mode. detects full harvest but no ice made. also condenser fan doesnt seem to be working.
o[en bin and look at your sensors, more then likely they have a scaley build up. the sensors are located below the ice maker and before the bin. It looks like a button of sorts one on each side, you can use a tooth brush to clean them. This should fix the problem
Jul 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
No ice
repalced the evap thermisiter and water fill sensor
Sep 04, 2009 | Scotsman DCE33PA1BC 15in Built-in...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
LG LFC25776ST 25 Cu.Ft French Door Refrigerator Factory RefurbishedFOR USA Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
