Question about Handpresso Auto Ese Portable Espresso Maker For The Car
Handpresso valve leak - Handpresso Auto Ese Portable Espresso Maker For The Car
My Frigidaire Refrigerator (FFHT2126PS) has a leak, how do I fix it?
The fitting shown is a John Guest fitting - releases by compressing the white ring around the tube - and if the leak is from any part of the valve you will need to replace the entire valve as they are not serviceable. Carefully check for the source of the leak first as water runs downhill and could be leaking from higher up and just dripping at the valve/fitting. The plastic tubing can age and become brittle or the tube connection at the other (higher) end may be leaking. Both are relatively simple and inexpensive to repair/replace.
Sep 13, 2014 | Refrigerators
What is a P2404 code mean from a suzuki sx4
Trouble Code: P2404 (2.0L L4 VIN 5 Automatic CVT)
Evaporative Emission System Leak Detection Pump Sense Circuit Range / Performance
Number of Trips to Set Code: 1
Trouble Code Conditions:
EVAP vent valve stuck open: EVAP leak check pressure is lower than -0.14 kPa even if EVAP vent valve is operated from OFF (OPEN) to ON (CLOSE) with EVAP leak detection pump ON. EVAP vent valve stuck closed: EVAP leak check pressure is unstable (difference between maximum and minimum is 0.36 kPa or more) when EVAP vent valve is OFF (OPEN) with EVAP leak detection pump ON. EVAP leak detection pump stuck OFF: EVAP leak check pressure is higher than -0.14 kPa even if EVAP leak detection pump is ON. EVAP leak detection pump flow high: Reference pressure of EVAP leak check pressure is lower than specified value (depending on BARO) EVAP leak detection pump flow Low: Reference pressure of EVAP leak check pressure is higher than specified value (depending on BARO).
Possible Causes:
  • EVAP leak detection pump (in EVAP leak check module) and/or its circuit
  • EVAP vent valve (in EVAP leak check module) and/or its circuit
  • EVAP leak check module and/or its circuit
  • ECM
Jul 11, 2014 | 2010 Suzuki SX4
Why isn't it working?
The heating element may be protected by a thermal fuse which is opening up, then resetting after cooling down.
Apr 17, 2014 | Handpresso Auto Ese Portable Espresso...
Air leak coming form the pressure switch
Air leaking from the pressure switch indicates that the in-tank check valve is leaking. Follow the air discharge hose from the compressor to the tank. The brass valve at the tank is the check valve. With air in the tank remove the inlet hose from the checkvalve and spray soapy water on valve to check for leaks. If leaking, remove the valve and check for debris under seat or replace. If the check valve is not leaking then pressue switch is leaking from within switch(spray soapy water below switch) . Good luck
Sep 23, 2011 | Dewalt 2 Hp 4 GAL Air Compressor
Have a craftsman 175psi 25 gal 3.5 hp fills up to pressure shuts down then pressure leaks behind what i think is pressure switch
Leak at pressure switch is an indication that the in-tank check valve is leaking.
Follow small hose from pressure switch to the tank (usually brass valve). Remove hose at the brass valve and check for leak there. If leaking replace valve with generic valve from ebay or WWw. grainger.com or use exact part (some valves can be cleaned, as debris can be lodged between seat). Good luck
Mar 26, 2011 | Craftsman Air Tools & Compressors
Compressor squeaks as pressure begins to build. Not from belt. Does not squeak when no pressure in tank.
Air leaking back from tank check valve or leaking reed valves can make a squeaking or vibrating noise. With pressure in tank remove fitting at the tank check valve and test for leak with soapy water. If leaking, replace with generic valve. If no leak, reinstall fitting and let all the air out of the tank. With empty tank and air filter removed, start compressor and feel strength of suction at intake. When you hear the squeak retest strength of suction at intake and compare. If reed valves are leaking, you will feel less suction as tank pressure increases, and in severe leaking valves, you will actually feel air blowing out of intake. Repair/replace reeds and /or leaking gaskets in head of compressor. Good luck
Mar 08, 2011 | Ingersoll Rand IngersollRand SS3F2GM...
Po 442 po 455
P0442 - Evaporative Emissions System Leak Detected (Small Leak)
P0455 - Evaporative Emissions System Leak Detected (Gross Leak)
This diagnosis detects leaks in the EVAP purge line using engine intake manifold vacuum. If pressure does not increase, the ECM will check for leaks in the line between the fuel tank and EVAP canister purge volume control solenoid valve under the following vacuum test condition. The vacuum cut valve bypass valve is opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP canister vent control valve will then be closed to shut the EVAP purge line off. The EVAP canister purge volume control solenoid valve is opened to depressurize the EVAP purge line using intake manifold vacuum. After this depressurization is implemented, the EVAP canister purge volume control solenoid valve will be closed.
Causes:
- Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Incorrect fuel tank vacuum relief valve
- Leak is in line between intake manifold
Solutions:
- Re-tighten or replace fuel tank filler cap
- Replace damaged or leaking EVAP canister
- Replace damaged or leaking lines.
Feb 10, 2011 | Chrysler Town and Country Cars & Trucks
Air compressor not filling tank
Most compressors with the problem that you are having suffer from leaking valves. As in a gasoline engine, leaking valves will lower efficiency. Valves in a compressor are in the form of reeds that seal against valve plate. Leaking reed valves or gaskets will increase the discharge air temperture. Inspect these parts with a magnifying lense. Look for evidense of wear or leaks. Also look for signs of air leaking from one cylinder to the other thru gaskets. Replace valve plate as necessary. Simple test, as your compressor is filling, check the intake for strong suction; as it neers the 92 psi mark suction will probably deminish if you have leaking valves. If suction remains strong at 92psi then you have a leak at the discharge side. Check with soapy water on all parts. Good luck
Jan 19, 2009 | Air Tools & Compressors
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Spout for frothing milk pops out
You can get the user manual on this link if you need it; http://www.gaggiaparos.co.uk/ Check page 6 of the download, page 12 of the manual - the spout should just pull off and push back on. If it wont, then either something needs cleaning more, something is stuck in the tube or more likely the part of the nozzle that comes off, something is broken, or you need to use a little bit more force. If it appears broken, (check in particular for a fine crack that is only visible when the nozzle is stretched i.e. when in place. This type of plastic often will close a crack enough to be near invisible when not under tension.) then you could try gluing it although i doubt if this would work. You could just put a stainless steel hose clamp around it, tighten up just enough to make the nozzle spout stay on (bit of a pain, but may work). You can contact gaggia for a replacement - in the USA; Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: sales@importika.com Hope this helps - if you can post back a photo or two close up of the problem area, i may have more ideas :)
Jul 05, 2007 | Gaggia Paros Espresso Machine
Handpresso Auto Ese Portable Espresso Maker For The Car Logo
263 people viewed this question
Top Handpresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Handpresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
