Question about Tatung WM42HDMT Television
I am having issues with the external speaker setup for my Tatung WM42HDMT 42". No sound. I have checked the menu on the TV and the audio is set to External. I have a left and right (home theatre speak
RCA audio outputs are lined in to Beats By Dre Beatbox (volume is up and power is on). External output selected on TV. PS3 hooked up to TV and audio output is S-Cart. Only other options were HDMI.
  • 26 Answers
Try this go to control panel click on sound your device should be listed click on it and make it your default device
Posted on Feb 13, 2014
2 Suggested Answers
gjahn
  • 110 Answers
SOURCE: I need to Identify external speaker connections for Tatung
Should be marked AUDIO OUT.
Posted on Jan 31, 2010
No sound on lcd tv
First check your TV setup menu to see if your TV audio preferences are set to PC audio. That is a setting that sends audio out through your PC cables instead of the TV speakers. It may also have been set to mute through a remote.
May 02, 2016 | Samsung LN40D630M3F
Trying to hook up surround sound receiver just like the manual shows but I cant get any sound from the tv but I can get music from the tuner part any suggestions?
Have you enabled the external speaker option on your TV and the set isn't on Mute? Check that you have the surround system's receiver set to the correct input. Next, check the audio level. On some sources for the TV, I need the volume at 65. Other sources sound fine with the receiver at 45. Check that the audio matches that being sent by the TV. On my TV, I needed to go to the Menu > Audio Settings to find the option for turning on the external speakers. Then I had to set the speaker system to Multi-Channel for our specific setup. (There were several options, including Dolby. For my specific setup, these other options didn't give the correct sound.) Finally try a different audio cable between the TV and the receiver.
I hope this helps. Please add a comment with the make and model number of your TV for additional advice. Adding the type of connection (digital audio (optical/coaxial), HDMI, RCA) will help me suggest potential problem areas.
Apr 21, 2015 | Audio Players & Recorders
No sound coming from speakers
Do you have sound when playing a DVD etc via the rear audio/video Jacks?
If so:
Look in main TV menu for speakers: ON or OFF settings.
If using a box for signal look to it and TV to make sure sound not off or turned low (if direct to set from box unplug box and plug back to reboot it)
If set has connections on rear for external speakers there may be a setting or switch to select either internal or external speakers.
If NONE of the above resolves this issue set has a audio circuit problem and needs a shop to repair this.
May 02, 2012 | Harsper HP-4200M 42 in. Plasma Television
CANT FIND A EXTERNAL SPEAKER SET
before attempting that:
Look in set menu to see if speakers are switched ON or OFF.
Check on SET and a Box if used that sound is not turned off or low.
If set has hookup for external speakers is external or internal selected.
Does the set have sound when a DVD etc. is connected via one of the rear sets of audio/video input jacks?
SD TECH
Apr 24, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
ViewSonic Speakers won't work
Sound issues and answersA VERY SHORT LIST OF ISSUES AND ANSWERS-
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD. (IF SOUND WORKS VIAREAR INPUTS IT IS A SETTING IN THE TV OR THE BOX.
Apr 07, 2012 | ViewSonic N4285p 42 in. LCD TV
I need instruction manual tatung wm42hdmt
hi there, i need to know what type of antena i have to buy for tataung tv model no: P42BSMT year:2005 .do i need any thing else to get the tv started? i really appreciate your reply . Thank you . Sakib .
Feb 09, 2009 | Tatung WM42HDMT Television
LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Nov 23, 2008 | LG DU-42LZ30 42 in. LCD HDTV
Programming Channels
If the set has been unplugged or has had a disruption in the power it may have to be setup again. Try going into your menu and go to the setup . Look around in setup for channel search of some kind. The set will search for channel signals in your area automatically once you tell it to. Then you should have the channels back. If this works then after it has run its search go to the AUDIO part of the menu and check that mute is off and that you did not turn off the internal speakers. If you are lucky and your set has plugins for external speakers, you can just get speakers to use with the set, but this is pretty rare. Check the rear panel on the set and see whats there. Most sets have an AUDIO OUT plugs that will pass the sound through your set to a home stereo for sound. Just run the lines from the audio out on the set to audio in on the amp or receiver of the sound system you have. Audio out will have a red and white plugs and just keep the red to red and white to white when hooking it up.
Sep 27, 2008 | RCA P52940 52" Rear Projection Television
Audio on and off
Nope sorry to tell you , the sound processor circuit has a fault and unless its under warranty be prepared to spend a hefty 400 to 600 bucks for the board.. Its not a set you can service unless you have the proper jigs and equipment. that why when i say buy an extended warranty on these sets, LISTEN TO ME!!! dont listen to a person who hasent a clue what it takes now a days to fix a plasma or a LCD tv set.. Good LUck
Aug 01, 2006 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Tatung WM42HDMT Television Logo
99 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
