Question about Behringer Eurolive B205D Active 150-Watt PA/Monitor Speaker System
Powering on and off
Run fine for around 10mins then begins to power on and off . Been told unfixable.. is that the case?
    Scholar:
    New Friend:
  • 125 Answers
Like as not, Behringer is a disposable brand once the warranty (which does not cover wearing parts like pots and faders which wear out quickly and are not worth replacing due to the design in most cases)
We normally sell behringer kit if it still works just before warranty expires.
Posted on Feb 18, 2014
Hi, i need to know the exact power plug so i dont have to run the pedal on battery power.i know i need a 9v power supply but i dont know the size of the jack that goes into pedal..many thanxs..
Unfortunately, battery jacks and plugs similar to the type you're describing do not have any real standardization - unlike the outlets and plugs in homes and businesses have.
You best bet is to either bring the plug / jack to a shop to match it or contact the instrument's manufacturer to obtain the connector specs for physical dimensions
Be sure to obtain the power requirements in either watts or amps so that you can obtain a power source capable of delivering what you need without overheating during longer periods of use. Adding 25% to 50% more amps or watts to the minimum required should provide years of trouble free service. Example: 9VDC at 50 watts should be supplied by a 9VDC 62 watts or even 75 watts; or in the case of a rating of 9VDC at 6 amps should be supplied by a 9VDC at 7.5 amps or even 9 amps. With DC powered devices, make sure you observe proper polarity! Good luck!
Mar 16, 2016 | Music
After 10mins or so my xr684f powers off
Power supply is overheating. Not user serviceable, you'll need to take it to a repair shop.
Aug 23, 2014 | Music
Possibel PSU Issue?
Could be a failing power supply as you suspect. You don't indicate the age of the equipment, but that could be a factor.
Mar 09, 2014 | Behringer XENYX 2442FX Mixer
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
For starters guitar center told me I could power down the sub and still mix on just the HS 50's. Also a major noise issue (Interference) With the sub powered up. With just the HS 50's I have no...
Noise issue: Make sure the following is adhered to:
ALL interconnected equipment is powered from the SAME receptacle or power conditioner.
ALL interconnecting audio lines are BALANCED, either XLR or TRS cables.
Read these "ALL"'s as just that. Some people unaware of the noise and HAZARD to their equipment will power mixers from one receptacle at one end of the room and speakers/amplifiers from one at the other end. The Professionals know better and run a heavy extension back from stage alongside their snake. Ground bounce noise is not only annoying, but can destroy audio input circuits.
Jun 12, 2011 | Yamaha HS50M COMPLETE AUDIO BUNDLE
It hs no instument lighting,Chanell level indicators and master level indicator
is there power to it? does sound come out of it? if not it could be fried or about to fry. Behringer makes low end products, which tend to break fast. if you dont have any sound or lights chances are its unfixable
May 25, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a new 1642 VLZ3. I have to turn the gain almost all the way up with all the mics and it still does not reach unity levels. What are the posible solutions or problems.
I would be surprised with all 16 mics active that you can't reach near a clipping level... Of course if you only have 8 mics active we would not expect to reach unity levels. Make sure this board is powered from the same receptacle as your amps. Powering it from building power at opposite ends of a room from where the amps are powered is asking for damage from ground bounce. The pros run a power back to the mixer alongside the snake.
Your trims will be fairly wide open for dynamic mics and your faders should be around unity during use. It is nice if the main fader can be around 50% or more. Use BALANCED lines everywhere including those running to the amps.
Mar 19, 2011 | Mackie 1642-vlz3 (16-ch 4-bus Compact...
I recently bought a Korg Pitchblack Tuner. It tunes correctly, (maybe a little slower than my Boss) but it will not power other pedals with the daisy chain. I am using a standard Boss wall wart which...
The tuner uses around 500 ma which may be nearly all your wall wart can put out... DO NOT overload the power adapter by daisy chaining other pedal power loads on it.
Feb 08, 2011 | Korg pitchblack + Tuner
When i power up the amp it makes a loud fuzzy wave sound then dies down a bit and you can play over it but the sound is weak and clunky. i took out the pre amp tubes and jiggled them around/cleaned some...
It sounds like your amp has one or more bad capacitors in the power supply. The AC mains input isn't being filtered properly, allowing hum and robbing the amp of the clean power it needs. It may be a case of bad solder connections, which is a very common problem in today's equipment. Another common trouble is capacitor failure due to under-rating the parts to keep cost down, leading to over-stressing and early failure. The shop you took the amp to should be able to check the caps and power supply operation, and replace any parts that aren't up to snuff.
Nov 23, 2010 | Peavey 6505 Plus 120W Guitar Amp Head
Roland XP 50 head phone problem
Looks like capacitor problem.Check power supply section also.
Mar 07, 2010 | Music
Behringer Eurolive B205D Active 150-Watt PA/Monitor Speaker System Logo
102 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
