Question about HP DeskJet 870cxi InkJet Printer
HP DeskJet 870cxi no lights
The printer is not working; it does not turn on; both lights are not flashing;
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
MCSE_Fixit
  • 23 Answers
SOURCE: hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Posted on Jun 18, 2009
princegh158
  • 56 Answers
SOURCE: hp deskjet 3325 light flashing have turned device
no problems
:just go ahead and take out the power cable when the printer is still on
:nw press and hold the power button fr 30 seconds
;while holding the power button,plug back the power cable
:nw u will be able to work well
Posted on Jun 28, 2009
  • 53 Answers
SOURCE: Printer (HP deskjet F4180) showing E and color
This means that there is issue with the Ink Cartridges.
Please remove and re-insert the cartridges.
Check the expiration date on them. Also make sure that you are using genuine HP Cartridges, not refilled or Remanufactured.
If the issue still persists, please replace the ink cartridges.
Posted on Jun 02, 2010
Testimonial: "Off to Staples to purchase new cartridges! Thanx "
  • 2567 Answers
SOURCE: left front indicator tear drop
Have you tried to clean the gold terminals in the print head where the ink cartridge's gold terminals make contact with? These could be cleaned by a non oil-based electric contact cleaner & a lint-free cloth while the printer is turned off.
These contacts might be dirty & not making good electric conductivity with the ink cartridges.
Posted on Feb 02, 2011
My HP 870cse thinks that the top is open and will not print. In-fact the top is closed. Is this fixable?
Dear friend,
There is a sensor on the mech assembly that pushes it on closing.I think it just something dismatled or mis aligne.Check with that.You can see the sensor just by opening the door.Hope i'll help.
Mar 07, 2011 | HP DeskJet 870cxi InkJet Printer
Printer (HP deskjet 870cxi) is making a loud
lubricate the rod using WD-40 by using a syringe
Apr 05, 2010 | HP DeskJet 870cxi InkJet Printer
Hp deskjet 3325 light flashing have turned device
no problems
Jun 28, 2009 | HP DeskJet 3325 InkJet Printer
Hp deskjet 870cxi not taking print
Reboot your computer, restart your printer and then check your printer print queue to see if any print jobs are stuck.
Jun 13, 2009 | HP DeskJet 870cxi InkJet Printer
Hp870cxi
periodically you need to clean the rubber paper feed wheels with isopropilic alcohol (tape head cleaner). They become hardened with age and the alcohol softens them again for a while and enables the to grip the paper.
Jan 29, 2009 | HP DeskJet 870cxi InkJet Printer
All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
Hi
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
Re 870Cxi Lights do not stop blinking cant use the printer
You can check if the print spooling service is enabled. go to services.msc and locate print spooler, right click and select properties, select automatic as the start up type and start the service. see if it works.
Jan 27, 2009 | HP DeskJet 870cxi InkJet Printer
HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Nov 01, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet 870cxi InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
