Question about Singer 3116 Simple
Change needle position
To use the zipper foot i need to change the needle position, how do I do this
    Novelist:
  • 268 Answers
Http://www.singerco.com/uploads/download/438_3116.pdf see p. 52. You change the position of the zipper foot, not the position of the needle, with this machine.
Posted on May 22, 2014
5 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: my 8280 modle singer: I sewed a zipper for a
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Posted on Sep 08, 2009
SOURCE: Singer Izek zipper foot
SewVacDoctor@sewingandvac.com
email them about the zipper foot
Posted on Mar 22, 2012
  • 1564 Answers
SOURCE: How to attach zipper foot on singer inspiration
Here is a copy of your manual.
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Most modern machines have snap off and snap on feet. Grasp the foot that is on there and push down. Then while lowering the foot, align the little bar on the zipper foot and watch it snap in. Easy.
Posted on Jul 08, 2012
  • 1564 Answers
SOURCE: Zipper presser foot
Is it fitted correctly? Some of these feet need to be helped a little to get them to snap into place. (press down on the presser foot bar)
Posted on Sep 05, 2012
I have a pfaff creative 7510. Which foot is the zipper foot and how do I change the needle position?
First here is a copy of the manual. PFAFF Creative 7510 Instruction Manual
Pg 96 shows a photo of the zipper foot, and directions on how to use it. I hope this helps.
Mar 02, 2017 | PfaFF Sewing Machines
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
How can I attach a zipper foot to my unidentified machine?
Assuming you have the correct zipper foot attachment for your machine, you should be able to attach it like any other presser foot. On some machines, you may need to adjust the needle position to the right or left so the needle will not hit the presser foot when stitching.
Feb 10, 2016 | Sewing Machines
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
How do I change the needle position
Depends on the machine, and if the needle position can be changed. If it can't, you probably want something like this: <http://www.sewingmachinesplus.com/j-200342003.php?gclid=CP7S5r-khL4CFc5ffgod9GUAlg> The green button thing on the back is a setscrew that lets you move the foot relative to the needle, rather than the needle relative to the foot.
Apr 28, 2014 | Bernina Artista 180
Move needle to the right
It doesn't look like you can change needle position on this machine. Even the zipper foot for this machine is made so the foot itself moves to the right or left rather than having to change the needle position.
Here's a copy of your manual.
http://www.singerco.com/uploads/download/438_3116.pdf
Sep 10, 2012 | Singer 3116 Simple
Would you please advise how I put a zipper foot on my brother bm-3600, the needle will not align with the foot when I put the foot down! Thank you.
Did a google image search, this looks like a newish machine so I'd assume clip on feet?
Put the foot on the pressure plate, lower the foot on and align so it clicks into place.
Couldn't get an image of the foot but many zipper feet are designed to mount either left or right side of the foot so you can sew both edges of the zip in the same direction, ie pressure foot to left of the needle for one side, and to the right of the needle for the other side of the zip, you want to stitch in the same direction to avoid creeping.
Some machines you change the change the needle position to the left or right in order to get up close to the zipper foot.
Probably a manual would assist explaining this better, if you don't have one for the machine, I'd suggest that you obtain one.
Mar 07, 2011 | Sewing Machines
I tried to change the position of the zipper foot and ended up breaking the needle and now the bobbin thread keeps snapping when I try to sew. What should I do to fix this problem?
There could be a couple of general reasons for this to happen.
First, the tension in the bobbin holder could have tightened when you were trying to fix the needle. I don't explain them, I just know strange things happen when you try to fix one thing.
Secondly, I can't tell how old your machine it, but I know that the mechanism that holds the bobbin holder can become jammed and the thread wound around it. That too will cause the bobbin to not feed properly. You need to be sure the area around the bobbin holder is clear of all threads.
How did you try to change the position of the zipper foot? Did you just change the needle position and move the foot to the other side or did you do something else? I'd need to have more information to tell you anything more specific.
Nov 28, 2010 | Kenmore Sewing Machines
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Singer 3116 Simple Logo
81 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
