Question about Zanussi WJS1397W Front Load Washer / Dryer
Settings dial has broken on my Zanussi WJS - 1397W
The dial has broken on my Zanussi WJS - 1397W. So that it no longer shows what washing setting it is on. What can I do? It washes well and I dont want to replace it. Is there a way of removing the front panel and fixing it manually? Thanks, Jamie.
  • Jamiebev Oct 28, 2007
    Yes this does alot thankyou :-)
    Problem Solver:
  • 10 Answers
You can go to this site and find/order the parts to fix it. It looks like the top of the machine just pops off (held down by clips) which then exposes the control panel and allows access to fix. Hope this helps.
Posted on Oct 28, 2007
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
May 27, 2011 | Zanussi FJS1225W Front Load Washer
Hi, ive got a zanussi jetsystem excel 1250 FJS-1397W model washing machine. it wont empty the water after a wash. could you tell me what to try or whats wrong? thank you, fiona
Locate and clean filter, which should be at bottom front right of washer, behind drop down or push down flap.
Unscrew anti-clockwise to remove and clean.
Jan 31, 2010 | Washing Machines
My zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
Oct 12, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Wjs 1397W. The water goes in OK. The
It was a bad joint on the motor control board. It was well burnt on one of the relay connections. I assume that the machine senses when the drive starts and then stops before changing the relays. Of couirse it only wend in one direction and was waiting for it to go in the opposite one before proceeding.
Jul 09, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi FLA 1001W washing machine - Programme selector dial
you can buy a new indicator as a spare - quite cheap. best souyrce would be service force - assuming you are in uk, its in the phone book
Feb 07, 2008 | Zanussi FLA1001W Front Load Washer
Zanussi WJS 1665 W Dryer
Your heat stats! or element!are faulty remove top to check them a meter would be usefull to check them,Advantage is! there easy to see stats!get back if you need to !or let me know!
Nov 11, 2007 | Zanussi FJS1225W Front Load Washer
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi WJS1397W Front Load Washer / Dryer Logo
397 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
