Question about Maytag MEW5530DDB Oven
Faulty control panel
Replace
Oven beeps and display shows F7
Error F7 means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
The code can be caused by a faulty keypad or a stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
a.- Pushing CLEAR/OFF pad.
b.- Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if code come on again, the problem is in the Control. Replace control to solve it. If code does not come on, problem is with the Key Panel
Hope helps.
Jul 07, 2011 | DCS WO-130 Stainless Steel Electric Single...
I have a es400 stainless steel stove. my right front burner stays on. please help .
You have a problem with the hotplate controller. The controller is faulty and requires replacing. The controller can be accessed by removing the panel behind the controllers.
Apr 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a GE built in oven Model JKS05B0WPBB and getting an F7 blinking light. Can you give me some guidance? Thanks.
Hi.
F7 on GE ovens means that there is a poor contact to keypad detected. When this happens the problem is either keypad or control panel.
Problem is fixed testing keypad and control assembly and replacing the faulty part.
Here the procedure to test the parts:
Hold down the CLEAR/OFF button on pad.
Disconnect the ribbon cable connecting control panel to pad and wait about one or two minutes to see if the code comes back.
If the code comes back, then you likely need to replace control assembly.
If the code does not re-appear on display, then the problem is with the key pad. In that case replace the key pad.
The procedure is only indicative. In case of faulty control assembly procedure may not be a definitive test. In that case replace the control pad first.
To find parts and diagrams for your appliance, enter the model number in the links listed below:
Where do I find parts and diagrams?
Aug 10, 2010 | GE Ovens
Control panel continously beeps with message to
Could be a faulty control as you suspect but also may be a bad keypad. If the "start" button has no effect I'm suspecting the keypad first.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | GE Profile JT912 Electric Single Oven
The top oven will not get hot. I replaced the temperature probe and just put in a new control panel. The bottom oven works fine.
Check the actual Switches themselves often they go faulty, and will not control the element.
Mar 26, 2010 | Ovens
Control switch for upper grille/oven is operating intermittently.ie. indicator lights not coming on. Is this likely to be the switch or the electronic control panel?
If` it is intermittent, it could be bad connection, or the control switch is faulty, if you can gain access to the control panel, check for bad or burnt connections, unlikely to be board, but not unknown for them to go faulty.
Please rate my solution.
Thanks.
Jul 15, 2009 | Neff U1721 Double circotherm Electric Oven
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Maytag MEW5530DDB Oven Logo
23 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
