Question about Zanussi IZ12 Front Load Washer
Machine wont spin - Zanussi IZ12 Front Load Washer
Kenmore washing machine model 20712990 wont spin
If you don't hear a click when you close lid, replace lid switch. If when in spin, you hear motor but does not spin, replace motor coupler.
Sep 02, 2014 | Kenmore Washing Machines
Washing Machine wont spin
Check out the safety switch that is switched on by lid closure . if this switch is faulty it wont spin.
Jul 18, 2014 | Washing Machines
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
Admiral top load washer wont spin
Are you saying the machine completely quits? Or it still drains and all just not spinning after the first time?
Jun 15, 2012 | Maytag Washing Machines
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Westinghouse LF708B washing machine wont spin,drains but wont spin Use to work when you thump machine but now wont spin at all
I have found that it is a blockage I manually drain the water through the botton of the machine then the cycle continues as a short term fix. I am not a professional though
Mar 09, 2010 | Westinghouse Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
