Question about Twin-Star International Inc Tresanti Cortina Dual Zone 18 Bottle Wine Cooler
Twin star cooler not working. Power to unit ok. Don't see any fuse
I have power to unit cannot find fuse control panel all electronic.Checked switch seems to be ok,thermostat does not click weather I go hi or low
Why a wine cooler edge star TWR215 doesn work
If you have checked the power outlet and switched it on, there is no way of diagnosing further from such a vague question. Is it completely dead? in which case it could be a fuse. More info would help
Jun 01, 2014 | KitchenAid KESC307 Electric Kitchen Range
Some power but not operating
Check out with a multitester whether the control panel switch on the power towards the high voltage transformer NNB disconnect the high voltage transformer for this test. if not the relay on the electronic controlle device is broken and the panel needs replacement. check also the 3 safety switches on the door for proper operation. mind the power it is dangerous.
May 10, 2013 | Sanyo Microwave Ovens
Blower wiring diagram in a 1994 jeep cherokee
Well, not exactly.
The blower switch gets power from the control panel that gets power from the 25amp fuse in the fuse box.
The wire from the fuse box to the control panel is black and tan, the wire from the control panel to the fan switch is yellow and brown.
lzauff1ar0seerf3d39vumdjuiq8an5p7moeygauw7naaaaaelftksuqmcc
Aug 20, 2012 | Jeep Cherokee Cars & Trucks
Wine cooler has no light or power working it simply shut down
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Jan 03, 2011 | Avanti EWC28 Wine Cooler
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Wine cooler Doesn't work
I had the same issue on a Whynter WC28S SNO 28 Bottle Wine Cooler, it even seems like most of the thermoelectric wine coolers, fridges, and such have the same boards by hanny. For cross refference parts I used NTE because Fry's Electronics had them.
Switching transistors - NTE51
1N 4007 - NTE125
Silicon Dual Power Rectifier - NTE6090
Also I have a venotemp wine cooler that has pretty much the same board, with the same plugs for fans, light, control panal, and cooler fan for $45 shipped at their site under replacement parts. Hope this helps people looking for info on this. Also research Switching Power Supply issues for information.
Oct 26, 2009 | Refrigerators
1996 Ford Windstar tail lights and dash lights stopped working
No. All those lights are on the same fuse and are controlled by the headlamp switch.
Make sure that the fuses were all checked on the fuse panel inside the vehicle under the dash. That is where the fuse for those lights is.
Sep 12, 2009 | 1998 Ford Windstar
Whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
No power
the problem is the power section Hot and Cold area. maybe you have defective fusibul resistors or in the oscillation circuit thats why your tv cant turn on automatically.
Sep 26, 2007 | Televison & Video
Twin-Star International Inc Tresanti Cortina Dual Zone 18 Bottle Wine Cooler Logo
73 people viewed this question
Top Twin-Star International Inc Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Twin-Star International Inc Furniture Expert? Answer questions, earn points and help others
