Question about Haier Heating & Cooling
Fixing Thermocool Split AC water leaking - Haier Heating & Cooling
4 Suggested Answers
carldc3
  • 82 Answers
SOURCE: LEAKING SPLIT TYPE AC
drain line is more and likely stopped up
Posted on Jan 23, 2009
  • 29 Answers
SOURCE: My onida split ac leaks water down the wall.how to
check to see if the drain to outside or your condensate pump is blocked with dirt, lift the unit off the wall and make sure the drain hose is correctly attached in the back of the drip tray. also ensure the unit is level using a spirit level.
cheers
Posted on Jul 05, 2010
  • 382 Answers
SOURCE: water leaking from the indoor unit of my split
dear sir
i think there is in indoor unit filter is dirty it,s need to clean and after reinstall there . water drain hose/pipe is block it.s need to clean.i hope after that your problem will be solve .
hope answer the question
thank you
please vote!
Posted on Oct 02, 2010
What's best way to insulate a house
Best insulation is by making thermocool ceiling. Next easiest thing is put curtain to all windows. Avoid dumping unused materials inside the ac room as it also produces some heat. Tnq
Sep 03, 2015 | Heating & Cooling
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Seting remote ac lg
Why water leaks from split type non inverter Air Conditioner?
Mar 24, 2013 | LG LSC121PMA Split System Air Conditioner
I have a Amcoraire that leak water during running AC
blow in to the drain from outside also check and make sure the filters are clean
Jun 07, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
May 04, 2010 | Sanyo Split System Air Conditioner
MY split ac is leaking water from the wall unit, it has been doin
Usually an AC unit builds up condensation. If you have a drain hoole or hose that is clogged up therefore not allowing the build up to drain off it will spill over the top of whatever housing the condensation goes into. If you can look for that issue first.
Aug 03, 2009 | GE Quiet-Aire Ductless Split System Air...
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Water leaking in
did you replace windshield?
do you have a sunroof?
these are the only places water could leak.
it could also be the condensation from the dehumidifier of the AC. maybe they forgot to reconnect the hose to expell the water.
Jul 08, 2008 | 2004 Audi A4
Heating & Cooling Logo
16 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
