Question about JVC Audio Players & Recorders
Volume settings How do i turn up volume on jvc tinyphones
Why? Jvc sound bar turning in by itself, no one turned it on, three mornings in a row , turned on radio automatically???
It sounds that you have accidently set up an alarm setting that is set to wake you up in the morning!
Look in the manual and see what it says about timer settings.
Aug 21, 2016 | JVC TH-BA1 Soundbar System with Wireless...
CAN NOT SET CLOCK ON MY JVC KD-G116
Is it KDG200 or KDG116?
In KDG200, press and hold SEL to display menu
Turn volume knob or press fwd or rev buttons to select CLOCK H and set.
Press Volume knob to save.
In KDG116, instead of turning the volume knob, use +/-. Instead of pressing the Volume knob use SEL
Mar 01, 2012 | JVC KD-G200 CD Player
How do I turn off the demo mode in my jvc kd-hdr44 radio deck?
Press and hold MENU. Turn volume knob to select group, press volume knob to select item, turn volume knob to select, and then press volume knob to save.
Mar 01, 2012 | JVC Car Audio & Video
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
How to set time onjvc car sterio
Try this:
Press and hold the SEL button to bring up the settings menu. Press and release the tuning (>>>) buttons until you see CLOCK H. Turn the volume knob to select the hour. If necessary, press (>>>) for CLOCK M; adjust the minutes setting with the volume knob. Press SEL when you're finished.
An owner's manual can be downloaded from JVC at this link:
http://support.jvc.com/consumer/support/index.jsp
Sep 29, 2010 | Car Audio & Video
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
How do I set the time on a JVC KD-S13 car stereo?
Press and hold 'SEL' button. DEMO is displayed. Use the up or down to select an item. Turn volume knob to set/adjust. The clock is next after demo. set hour then minute press SEL to finish. Reference page 3 in this link to JVC for your KD-S13 CD Receiver Instructions.
http://books.jvc.com/Download/975469902/GET0400-001A.pdf
Dec 27, 2009 | JVC Car Audio & Video
How do you set the time on the jvc kd-s35
Press and hold SEL button. Press ^ button 3 times to display H (hour) turn volume knob to change hour setting, press down 1 time to select M (minute) turn volume knob to change minute setting. Press SEL to finish the proceedure. Reference page 14 in this link to your JVC KD-S35 instruction manual.
http://books.jvcservice.com/Download/106224402/GET0563-001A.pdf
Nov 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
Can't set clock
hello Have radio on and then you have to hold down the SEL button on left for a few seconds. Then it will say "SET H" which is hour and turn volume dial left or right to move up or down. To set the minutes push either the left or right buttons on the selector on the far right. You can switch from minutes to hours here too. And once at "SET MIN" turn the volumes dial to go up or down. Hope it helps!! Took me a awhile to figure out (no manual here)
Dec 06, 2007 | JVC KD-S890 CD Player
29 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
