Question about Acer Aspire One D255 Laptop
Adisk read error occurred
A disk read error occurred press ctrl+alt+del to restart
    New Friend:
    Problem Solver:
  • 10 Answers
That usually means that your HDD (hard disk drive) is dead and its no longer readable. By start up pres F2 normaly thats the button normaly that will lead you to the BIOS go on overview and see if your HDD is still detected by BIOS. You can also try to see how bed things are by inserting a rescue disk on your CD/DVD drive press F12 when you do that and try to diagnose the problem. You can also try to reinstall your OS(operation system) sometimes that also helps but not in many cases. I Hope that help you a bit.
Posted on Feb 20, 2014
  • 34 Answers
SOURCE: won't start
sounds like maybe a hard disk problem but there is a couple of things to try go in the bios and see if it recnioze it and if it dont have u recently removed the drive sometime a loose connection will cause this.but if u have not removed the drive u should still check it to make sure it has a good connection.
Posted on Mar 24, 2009
byteguy
  • 2229 Answers
SOURCE: A Disk read error occurred upon booting
This could be a sign of the hard drive having a problem.
I would recommend that you do a scan of the hard drive to check for errors.
You didn't mention which operating system you have, but you need to click on My Computer and then right-click on your hard drive. Go to Properties and then Tools.
Once there, select the option that tells you to check the disk for errors. Check the entire drive. Note that this will not run right away. You must restart your computer, as the utility needs exclusive access to the hard drive.
If this type of error reoccurs, it's time to back up your data, 'cause you probably have a hard drive that is dying.
Posted on Apr 09, 2009
  • 10 Answers
SOURCE: not booting. "disk read error occurred"
This means you HDD is either corrupt or faulty, try downloading a copy of Hirens BCD to try to access the HDD (or use and external HDD enclosure) and if you can, put it back in the laptop, if not reformat it and reinstall windows.
Posted on Aug 11, 2009
bhaveshg
  • 3 Answers
SOURCE: "A disk read Error
It looks like problem with your Hard Disk Drive, your drive may have bad sector on it. You may have to remove yor HardDrive and connect it to other computer using converter cable which you may get in market or local computer shop to backup your data. If you already have backup with you, register call with acer support website and get it replaced free if under warranty.
If this laptop is not under warranty, you may have to buy new harddrive and replace it and restore your Operating systems, programs and data.
Hope this helps.
Posted on Dec 06, 2010
joelwilcox
  • 1274 Answers
SOURCE: when i start my lap top is say's a a disk read
it is entirely possible that the boot sector is damaged. if this is the case you need to boot with the cd that came with the machine, or a recovery cd you've made, and load the recovery environment. once their load the command prompt. it should just be a button in vista or 7 and it will automatically load in xp. once loaded type "chkdsk c: /r" no quotes. let it run, this will check for bad sectors and should fix the issue. try and reboot, and let me know what happens. if you don't have the recovery cd's or installation media you can download msdart, which has the recovery console built in. i went ahead and uploaded msdart, download the version you think you need. https://rapidshare.com/files/2296685117/ERD50_x86_WinXP_SP3_blueforce.ziphttps://rapidshare.com/files/2914560443/ERD60_x64_WinVista_SP2_blueforce.zip https://rapidshare.com/files/267688033/ERD60_x86_WinVista_SP2_blueforce.ziphttps://rapidshare.com/files/1400985026/ERD65_x64_Win7_RTM_blueforce.ziphttps://rapidshare.com/files/3314839442/ERD65_x86_Win7_RTM_blueforce.zip
Posted on Feb 17, 2012
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
Disk read error occurred, press ctrl+alt+del to restart, but it just takes me . ... press ctrl alt del to restart" problem, HOW TO SOLVE
Have you checked your bios to see what the system is configured to boot from first? Make sure your hard drive is the first boot device in the list.
Oct 28, 2013 | eMachines D620 Laptop
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
I have a optilex 170l dell computer i replaced the hard disk and now i gives me a disk read error occured press ctrl+alt+del to restart
Press ctrl+alt+del to restart is just an instruction. Did you do it?
What happened? Was it read? Tell us more. Send your e-mail for
us to give you our feedback.
By the way, assuming that it did not work, Your hard disk must be
configured to your PC, by running a software driver for your new hard
disk. You can download it from the internet by running search " hard
disk driver". Just specify the brand.
Oct 17, 2009 | Dell Computers & Internet
Restart Error: "A disk read error occured Press Ctrl+Alt+Del to restart"
Turn the pwr off for 5 minutes
turn the pwr on and tap the F8 or press the F8, 8 times
and select safe mode and do a system restore
Jun 01, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Acer Aspire One D255 Laptop Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
